Go Back   Automotive Forums .com Car Chat > Plymouth > Acclaim
Old 02-27-2011, 09:07 AM   #1
jvorrius
Send a message via Yahoo to jvorrius
94 Acclaim 3.0 code 34
Hi,
I have a 1994 Plymouth Acclaim 3.0 v6 with 145,000
I keep up with all tune up and maintenance items.
Wires, plugs, cap, rotor, coil, gas filter are new in the past 6 months.
In the past week a problem has occured that I can't pinpoint.
The car runs great on the highway but when it idles and driving around the city it hesitates and wants to stall. It does stumble and stall occasionaly.
It sets a code 34. The throttle body is cleaned every other oil change. The idleing and stalling makes me think it is a bad IAC motor but not sure if that would set a code 34. Any help would be appreciated.
jvorrius is offline   Reply With Quote
Old 01-01-2012, 05:28 PM   #2
P2000
Re: 94 Acclaim 3.0 code 34
My car was doing the same thing, but then I looked at the engine code more carefully. The blinking cadence is kind of ambiguous, I finally realized that I actually was not getting a code 34 (which didn't make sense anyways), I was getting a code 12 and then a code 13. The vacuum line to the MAP sensor was fine, the connections were fine too. After replacing the MAP sensor the stalling/skipping problem went away and it runs better. I hope this helps.
P2000 is offline   Reply With Quote
91 mighty max 3.0 parting out Rip_Jeff Mighty Max 0 07-27-2010 06:04 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
96 voyager 3.0 - code 12 72 !! jibu_25 Caravan | Voyager 0 06-30-2006 06:17 PM
2000 3.0 code 0402 2000mudder Ranger | Courier 5 05-28-2006 05:16 PM
97 Voyager 3.0 code 43 pilotnmech Caravan | Voyager 0 01-08-2006 08:23 PM
