Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 08-29-2010, 01:12 PM   #1
wrbol
Unhappy 2002 s-10 clutch switch
I noticed the clutch pedal had to really be pushed to the carpet to enable starter. finally won't attempt to start at all. tried to push start vehicle but noticed security light blinking and no start. finally uncovered and found i believe 4 wires. probably includes security wires. which wires do jump to start. it looked like there were 2 purple w/ white stipe a gray? and another plain purple
wrbol is offline   Reply With Quote
Old 08-29-2010, 04:09 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 2002 s-10 clutch switch
Did security light go out after key off and back on?
If not you may have a problem there.
Is it a add on anti theft or remote start thing?
Are the two purple/white wire connected together on same terminal?
The purple is fuse power to starter clutch pedal switch.
Make surer power on it.
Purple and white wire goes to starter real from pedal switch.
Jumper the purple 12 volt wire to the purple and white wire and see if it starts or clicks start relay.
MT
MT-2500 is offline   Reply With Quote
