Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 07-22-2010, 02:30 PM   #1
mark_gober
P0171/0174 post recall
Hey everyone,
I'm looking for opinions. I've got a 2000 Windstar that had already had the recall done it prior to me owning it. I didn't know this and about 6 months ago, I purchased/installed the kit to fix it. (so it's doubly fixed, I guess you could say).
The car has 150k miles on it and it began stumbling about 8 months ago (hence the installation of the recall). When I got into the engine, four of the spark plugs were crusted over to the point of nearly bridging the gap. I put new ones in and it ran fine.
Recently the car began a VERY slight stumble at freeway speeds and assuming that I had fouled some more spark plugs, I bought new ones and changed them out. This time, 5 of the 6 looked great, but the front-middle plug had a decent amount of crust on the electrode.
Here's the problem that I'm having now. The engine seems to idle pretty smoothly, but left alone, it'll abrubtly die in about 1-2 minutes. It immediately starts right back up and if left alone, will abrubtly die in another 1-2 minutes. It will not die when the throttle is used or when going down the road. The check engine light came on and it reads a 0171/0174 combination.
The employee at autozone thinks it's a bad MAF sensor. I climbed in the hood and checked for any sort of disconnected vaccuum tubes or other things out of place and didn't see anything. Anybody think that a MAF sensor would cause this problem? Got any other ideas?
Mark
mark_gober is offline   Reply With Quote
Old 07-22-2010, 02:46 PM   #2
phil-l
Re: P0171/0174 post recall
Well, let's start at the simplest point first. Whenever I hear "Windstar idle problem", I automatically ask "Did you clean the IAC?"
It's easy and quick to do, so I'd eliminate it as a concern before moving on. Here's the info you want:
http://leckemby.net/windstar/windstar02.html
I'll also note the a recurring 0171/0174 after the isolator bolt seal fix is often a sign of a vacuum leak. Are you sure all manifold tubes are properly connected?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
phil-l is offline   Reply With Quote
Old 07-23-2010, 01:22 PM   #3
mark_gober
Phil,
Thanks for the input. I've had issues with an IAC before. But that typically manifests itself during cold starts. My car starts fine and will idle for perhaps a minute or two before it abruptly dies. Also, I don't remember my IAC throwing a code. (Maybe it did, I just don't remember it doing it.)
In regards to the manifold tubes, I installed that recall at least 6 months ago and I've not had ANY problems since. This just came up suddenly.
Mark
Old 07-27-2010, 08:19 AM   #4
mark_gober
Problem Fixed.
I borrowed my brother's 2003 MAF sensor and started the engine. It ran for about 2 minutes and died again. Aggravated, I took the snorkel assy. back out and immediately found my problem. Just on the back side of the butterfly assy, there is a large vacuum hose that leads to the firewall. I had accidentally knocked it off the nipple when I changed the spark plugs. As soon as I reconnected it and the MAF, the engine started right up and runs like new again. I've cleared the codes and it's still good. Thanks for your input.
Mark
Old 07-27-2010, 10:36 AM   #5
phil-l
Mark -
Good news!
You aren't the first Windstar owner who completed the isolator bolt fix - and then later had a loose vacuum hose cause problems.
1995 Contour GL 2.5
