| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#1 | |
i have a 1999 s-10 zr2. it will start and idle fine, but whenever i put the truck into gear it will stall. i have replaced the following parts: tps, map sensor, ignition control module, plugs, wires, coil, cap, distributor, battery, and fuel pump. i am running out of money to throw away, please help asap!!!
#2 | ||
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Re: please help
Any check engine lights? On the stall does the idle RPM slow down making it stall or does it just quit? Or other words is the IAC controlling good RPM to keep engine running? What are idle RPM at idle and in gear and out of gear? Does it run good on the road?
#3 | |
Re: please help
it has the 4.3 vortec. it won't make it to drive it on the road. the rpms are about 6-700 at idle. when you put it in gear, or turn on the heat/air the motor will idle down untill it dies. also no check emgine lights.
#4 | ||
AF - Advisor
Re: please help
Check the IAC idle air control valve for working right.
#5 | |
Re: please help
the motor will run forever if you let it sit untouched. where is the iac valve located?
#6 | |
AF - Advisor
Re: please help
