| Latest | 0 Rplys |
01-18-2005, 06:49 AM | #1 | |
Trouble Pumping Gas
OK...I know what you're thinking...How could any moron have trouble pumping gas?
I have a 99 Accent GL sedan, which has served me well. Never any significant problem that wasn't immediately handled by warranty. Recently, however, i've had a heck of a time putting gas in the thing. Not matter which service station I try, after a few seconds the pump will click off as if the tank is full, and it sprays gas all over the place. This never used to be a problem. I usually get so frustrated and/or worried about getting gas all over my clothes that I leave the pump with only a couple of gallons. Anyone else experienced this? |
01-18-2005, 03:31 PM | #2 | |
Ex-Janitor of AF
hmmm, I never heard of that happening to any vehicle. Plus, I do not recall seeing anything about that either in Webtech. I wonder if anyone else has an explanation. I'm curious myself to know what can cause such a thing. Unless there is a build up of gases in the tank, but that would cause me some concern.
lowsonoma / mazdatech, care to add? TS out
The more the members are involved in the process of development, the better we will be as a community of Automobile enthusiasts. Have a suggestion to make the community better, let us know. Remember, the "No" is always there, you are just looking for the "Yes" Members please read: Guidelines |
01-19-2005, 01:19 PM | #3 | |
Re: Trouble Pumping Gas
I would guess that either your fuel cut off valve is not working properly or your fill vent vavle is not letting vapors escape see enhanced emission diagram for your model on the webtech site for diagram......or if the fill vent valve line was plugged/pinched it might cause this.
01-19-2005, 08:33 PM | #4 | |
the only things that could be is either your holding the pump incorrectly (try pulling the handle out just al little bit or angle it differently) or you have a big ass dent in you gas tank im sorry but a car doesn't have a fuel cut off valve mazdateck is just a retard
the fuel shutoff is in the pump!! every thing that deals with the feul system consists of trigger contact aka:trigger points fuel injection valves air flow sensor resastor unit air mass sensor cold start valve electric fuel pump enjine tenp sensor frequency valve aka:timing valve throttle valve switch fuel filter idle control unit gas tank idle speed stabilizer fuel pressure regulator knock sensor oxygen sensor s pressure damper fill neck gas tank gas cap relay fuel distributor rpm sensor throttle position sensor vacuum limited devise overrun cutoff valve aka: decel valve pressure sensor auxiliary air valve fuel accumulator thermo time switch electronic control unit control pressure regulator fuel rail fuel injectors some extra little s##t |
01-20-2005, 12:48 AM | #5 | |
really
Before you reply please refer to www.hmaservice.com TSB# 00-30-003 ie.1999 Accent ORVR/evaporative system schematic I am not here to argue or belittle people but you make it very easy....... |
01-20-2005, 09:41 AM | #6 | |
Ex-Janitor of AF
If you do indeed look at the schematics, you will see that the 1997-1998 Accent does have a Fuel Cut off valve located within the fuel tank, see diagram below.
The 1999 Aceent also has one, but its labeled Fuel Shut-Off valve.. The 2000-2001 accent also has the Fuel Shut-off valve.. Apparently Hyundai is using both name decriptions for the same part. They just changed its naming after the 1998 MY. Proof of that is at the bottom diagram for the Santa Fe. It shows the name label of "Fuel Shut-Off (cut) valve". TS out
01-21-2005, 08:01 PM | #7 | |
i retract my previous statment
01-24-2005, 11:23 AM | #8 | |
Wow...thanks for all the info!
Now it seems like I've got some ideas on what's wrong. BTW...my check engine light came on, too. A buddy brought in his code reader and it reads P0455: EVAP Emission Control System Leak (Large). Related problem? But, from the details you guys have provided, it looks like this valve is inside the gas tank. Is this something the average guy (I can change oil, but not much more) can handle. Or should I head off to my mechanic? Or, am I forever doomed to getting $1.75 worth of gas, and having $.75 worth on the side of the car and $.50 worth on the ground? Last edited by Glamdring71; 01-24-2005 at 03:09 PM. |
01-26-2005, 11:25 PM | #9 | |
I reccomend you take it in to a qualified hyundai tech. They will hook up an evap tester and verify the leak so it is repaired correctly. If it is a valve on top of the tank than the tank will need to be lowered/removed for repair. mske sure you tell them of your original problem to
01-30-2005, 11:21 PM | #10 | |
I can garauntee you it will be the canister close valve and filter the plug up and cause the fuel to shut off cause it cannot get out of the neck fast enough.
www.toontoys.ca THE WAY YOUR GIRLFRIEND LIKES IT...BIG AND DIRTY!! |
