Go Back   Automotive Forums .com Car Chat > Toyota > Avalon/Pronard
Old 04-01-2013, 08:34 AM   #1
mscmor
1998 Avalon rough idle at hot intermittently
I'm having the some trouble with my 1998 Avalon (70k miles).
Runs really rough only hot, intermittently. Starts to happen after a slow down going from high speed to lower speeds. Once it starts it normally keep happening until the car is shut off for 10 - 15 minutes. Sometimes I can take a 200 mile trip with no trouble, then later on it happens randomly on 5 or 30 mile trips. If it happens it always goes away after a 15 minute off period.
I checked a bunch of vacuum lines on top of the motor for leaks, took the egr valve off and cleaned it and replaced a coolant temp sensor.
I've heard people say maybe the MAF sensor can be dirty. Might try cleaning that next.
Thanks for any feedback, you may have.
mscmor is offline   Reply With Quote
Old 05-27-2013, 04:26 PM   #2
jamesslcx
Re: 1998 Avalon rough idle at hot intermittently
Old post I know but mscmor, have you fixed it yet?
jamesslcx is offline   Reply With Quote
Old 05-27-2013, 06:30 PM   #3
mscmor
Have not fixed it yet. I gave my 77 year old dad an ODBII code reader. It only happened once since March this year.
I'm going to have him pull over in a parking lot when the issue happens, keep the car running, and check for codes real time while the issue is happening as a next step. This one has us confused. I'll post something when the info comes through.
Thanks.
Old 05-27-2013, 10:06 PM   #4
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
The codes should stay in the ECM memory. You don't need to access the codes real time.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 06-01-2013, 07:08 PM   #5
toyotech MDT
Egr valve is sticking
toyotech MDT is offline   Reply With Quote
