| Latest | 0 Rplys |
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series. |
01-17-2006, 08:01 PM | #1 | |
1996 XJ6 misses at idle!
Hello, I have a 96 xj6, with about 130k on the odometer, currently the engine misfires at idle every 3 to 5 seconds. When driving it runs smooth as ever and has slightly less power, but thats probably due to the age of the engine. If you have any advice to remedy the problem I would greatly appreciate your help.
08-17-2006, 07:36 PM | #2 | |
Re: 1996 XJ6 misses at idle!
Clean the throtle body. Do you have a check engine light on? You could have oil around the spark plugs(bad cylinder head cover gasket), deposits around coils, bad coils.
The engine is not old at 130k. |
07-26-2008, 12:25 AM | #3 | |
remove the coils and sparkplugs.remove the boots from coil pacs and check for oil.more than likely the problem.just clean up and replace cam cover gaskets.
07-26-2008, 12:39 AM | #4 | |
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
