| Latest | 0 Rplys |
03-20-2015, 08:52 PM | #1 | |
89 caprice codes 12, 24
Granted I know 12 is normal 24 is speed sensor so I ran out and ordered one but no clue where to find it on the car.
Thanks |
03-21-2015, 07:13 AM | #2 | |
Registered Offender
Re: 89 caprice codes 12, 24
For many of the pre-1991 cars the VSS and the yellow VSS buffer box were mounted to the rear of the speedometer. If there is a speedometer cable on the transmission, the VSS is likely on the speedo.
Be aware that the lack of a VSS signal may not be due to a faulty VSS. That 2K/4K signal splitter and buffer can fail, or may not have connection, or may not have power.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
03-21-2015, 08:25 PM | #3 | |
Thank you ok I didn't you know that because the speedometer had stopped working so I replace the cable today and the speed sensor they give me at the parts store look nothing like what the electrical connection by the speedometer cable on a transmission so I returned it. test drove the car the light still came on as soon as I release the accelerator after driving at highway speeds the light flashes on. but there was nothing attached to the back of the speedometer
03-21-2015, 08:28 PM | #4 | |
what is a 2k /4k and how do I check it
03-21-2015, 09:06 PM | #5 | |
Confoundingly Lucid
If the speedometer cable was broken, that would be why you got the code 24. The VSS, as Blue Bowtie stated, is located on the rear of the speedo head. If the cable isn't turning the speedo, then the VSS won't read.
Get the speedometer working and your problems will go away.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
03-21-2015, 11:27 PM | #6 | |
Thank You
03-23-2015, 05:53 AM | #7 | |
Ok new speedometer cable is in still have the code 24 and now 32 right rear speed sensor incorrect input. You mentioned a 2K/4K earlier I am not familiar with that thanks for the help thus far
03-23-2015, 09:11 AM | #8 | |
[quote=frued1961;7159525]Ok new speedometer cable is in still have the code 24 and now 32 right rear speed sensor incorrect input. You mentioned a 2K/4K earlier I am not familiar with that thanks for the help thus far...... [quote]
PUT the old sensor back in . disconnect the cable operate vehicle see if the cable rotates.. |
03-25-2015, 02:04 AM | #9 | ||
Confoundingly Lucid
03-25-2015, 05:09 AM | #10 | |
Cool thanks I couldn't see anything looking like a sensor in my sense of sensors now I know it's there Thanks
03-25-2015, 06:33 AM | #11 | |
Oh can a person clean up the EGR valve and it work properly afterwards
03-25-2015, 12:41 PM | #12 | |
NO .. these style valves are good for 10 years then they fail to operate as designed.
they fail many ways not just from debris/carbon.. |
03-25-2015, 02:15 PM | #13 | |
thank you again
