Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 06-03-2012, 01:31 PM   #1
zepol
2001 Grand Prix GTP - Major Oil Leak
This is on a 2001 Grand Prix GTP. Yesterday while driving home my car started smoking (Oil hitting the exhaust pipe) and then when I parked I seen a huge puddle of oil. I took everything apart this morning to see this. It looks like the sensor that is connected to the oil filter that checks the viscosity? I tried to see if there was play in it but it didn't seem to be loose. Any ideas would be greatly appreciated. Thanks.
zepol is offline   Reply With Quote
Old 06-03-2012, 02:16 PM   #2
Tech II
Re: Major Oil Leak
Actually, it doesn't leak out of the motor, it leaks out of the electical connector......easily replaced.....
The Following User Says Thank You to Tech II For This Useful Post:
zepol (06-03-2012)
Old 06-03-2012, 02:18 PM   #3
DeltaP
Re: Major Oil Leak
Thats more than likely the OIL PRESSURE sender switch. They'll leak at the sealing area between the metal shell and the plastic insulator. Pretty easy repair. Even a caveman can do it! But I dont think thats the only leak ya got on that engine.
DeltaP is offline   Reply With Quote
The Following User Says Thank You to DeltaP For This Useful Post:
zepol (06-03-2012)
Old 06-03-2012, 02:34 PM   #4
Tech II
Re: Major Oil Leak
Yeah, DeltaP is right, it is the oil pressure switch.....the oil is hitting the axle and is flinging it everywhere......after replacement, lay papers down and wash down the P/S pump, block, oil filter housing, power steering lines, cradle, etc., with Brake klean......then road test and recheck for leaks....
zepol (06-03-2012)
Old 06-03-2012, 02:59 PM   #5
zepol
Re: Major Oil Leak
Thanks you guys! It sure does look like more than one leak
Old 06-03-2012, 03:13 PM   #6
tblake
In God We Trust
tblake's Avatar
Re: Major Oil Leak
3800's can leak oil out of the Oil Pressure Sender like you describe. They can leak out of where the connector plugs in, or also out of where the plastic mates the metal. I have seen both places leak.
The oil filter adapter gasket is another common leak spot. Based on the pictures, I'd replace the Oil Pressure Switch. They are fairly inexpensive, and easy to replace, Just unscrew.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
tblake is offline   Reply With Quote
The Following User Says Thank You to tblake For This Useful Post:
zepol (06-03-2012)
Old 06-03-2012, 08:14 PM   #7
DeltaP
Re: Major Oil Leak
I was referring to the half dried,caked up mess on top of the filter head and the dirty Fram.
Old 06-03-2012, 09:15 PM   #8
zepol
Re: Major Oil Leak
New oil pressure switch did the trick. Next week I will do my annual plastic coolant elbow change and the supercharger pulley that has been rattling.
1994 Major Oil Leak velli Explorer | Explorer Sport Trac 1 01-13-2005 09:09 AM
Engine Won't Turn Over and Major Oil Leak After Having the oil changed Last Night!!! mepammy Engineering/Technical 16 12-23-2004 06:35 PM
Help! Major oil leak, new engine? rjeffas Blazer 10 12-06-2004 11:43 AM
major oil leak 93 p71 93interceptor Crown Victoria 2 11-24-2004 09:52 AM
Need Honda Accord Major Oil Leak preludes10 Accord/TSX/Accord Hybrid 3 08-30-2002 09:05 PM
