| Latest | 0 Rplys |
04-27-2007, 01:29 PM | #286 | ||
Re: INTAKE GASKET MAIN PAGE, PLEASE POST Q'S&A'S HERE!
I thought that was the case, thank you, I'll remember tomorrow when I start putting everything back together. Received serious rope burns pulling the engine forward, BTW, do you know the GM part Number for the original spark plugs? The ones in there now are 41-940, they look a little warn, but not bad, I can't tell if they're original, the van has 130k miles. Also, #1 cylinder was full of green antifreeze, the other cylinders weren't. I'm anxious to get this back together, your recommendation about removal of the rear head with the exhaust manifold still attached was a life saver. I keep reading about replacing the oil something o-ring? And, Bob said there pictures of the complete breakdown somewhere on line? thanks, Mark |
04-28-2007, 10:11 PM | #287 | ||
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
04-30-2007, 10:55 AM | #288 | |||||
Anyways, you'll need to remove the bolt that is holding the bracket down and lift the shaft straight up. A pair of vice grips or channel lock pliers make the job easier. You can ding up the top of the cap without problems, but don't put anything between the block and the bottom of the cap. You want these surfaces to be smooth. Once you get it out, there will be an o-ring a little ways down on the shaft. Mine basically fell apart when poked at with a screwdriver. Reinstallation is reverse of the process. The drive shaft sometimes will want to slip out of the cap. A little bit of axle grease in the top of the cap provides enough stickyness to keep the shaft in place for reinsertion.
Vinyl adds horsepower, right? |
04-30-2007, 08:29 PM | #289 | |
If you think you had a leaking head gasket have the heads pressure tested at a machine shop while they are off. This will save you a lot of work if one is cracked.
05-04-2007, 03:04 AM | #290 | ||
05-19-2007, 08:20 PM | #291 | |
Just finished, got everything back together, started right up, these forums are fantastic! Did not replace push rods exactly, but had the right lengths in the right order, do not notice any rattling. Electrical plugs will only go in one way, however, vacuum tubes, that's another story. Recommend bagging and tagging all bolts, and labeling all vacuum and electrical connections. Pre-mark both ends of new spark plug wires, the ones I bought did not have numbers on them. Install EGR to upper intake, loosely, before installing upper intake. Take lots of high quality phots, could not find a single photo of my actual engine anywhere except EBAY and autozone.com, had to improvise with other year models. Where the heater pipe, EGR, fuel lines, Tansmission dip stick meet can be a bear, make sure you have a good photo, if you can disconnect both the fuel lines and by-pass pipe, I highly recommend doing so, or at least one of them. Lastly, I want to echo the previous poster's comment about how gratifying it was when the van started up.
05-19-2007, 09:02 PM | #292 | |
Hi,
I too have gasket troubles and am attempting to fix it myself. I was trying to rotate the engine, but it didn't leave me much room to remove the ignition coil. As a novice wannabe mechanic who is using the haynes manual as a guide, I wanted to know how far is the engine supposed to rotate? Enough to easily remove the coil?? |
05-20-2007, 07:39 AM | #293 | ||
05-20-2007, 12:16 PM | #294 | ||
Good luck, just take your time and dont take short cuts and youll do fine. BTW im a motorcycle mechanic and an auto body man and it took me all day, so guage your time on that. |
05-20-2007, 10:34 PM | #295 | ||
05-21-2007, 07:56 AM | #296 | ||
05-21-2007, 09:12 AM | #297 | ||
05-21-2007, 11:16 AM | #298 | ||
You will also want to get rid of the MAP sensor and bracket (black square box right in front of the coil pack with a couple of vacuum lines attached) take the sensor off the bracket and then pull the bolt off of the unpper intake to get the bracket off, be careful with the vacuum line from the MAP sensor to the fuel pressure regulator, I snapped mine off the second or third time I pulled the MAP sensor. Pull the vacuum line from the intake to the power brake booster. You can flip the hose over under the cowl or just pull the fitting out of the brake booster and pull the hose completely out, careful the hose fittings on the intake and the brake booster are plastic! Get the wire harness out of the way as best as you can, if you want everything is going to get unplugged anyway so remove all of the connections and flip the whole harness over the radiator, note where all the connectors go. There are 2 connections you have to keep track of, the O2 sensor is on the back exhaust manifold (who's F---en idea was that!) and the crank sensor wire is on the back side of the engine. The 3 pin connector that goes to the back drivers side connector on the coil pack (This is the crank trigger wire) doesn't attached to the main wire loom so you might want to tie a piece of string to it. I wasn't watching for it and it got trapped under the throttle body, I didn't notice until I went to make all of the connections on the coil and wound up having to strip everything off to lift the upper intake so I could get the damn connector out. Trust me, the engine will not run without that connection. Some of the connectors like the O2 sensor have a locking pin that goes through the release mechanism, they can be a pain in the ass to get out, just do the best you can with a pair of needle nose pliers. Get a ratchet with a 13mm deep socket and a 3-4 inch extension, use your hand to guide the socket over the nut on the stud, just run your finger along the aluminum mounting plate from the passengers side to the drivers side, you will feel the nut. Then just guide the socket over the nut, you should just have to back it off 1 turn then spin it off with you finger, there is a tip on the stud so you will have to grab the nut to take it off, use a magnet if you have to, don't drop it because it probably won't make it to the ground. Good Luck, Steven Last edited by Sparky1349; 05-21-2007 at 01:35 PM. |
05-22-2007, 05:05 PM | #299 | |
hey sparky,
thanks so much for all the info, it is helping me immensely. quick question: did you remove the passenger strut mount to take the valve cover off?? it is a real pain in the a@# to get it off with the strut mount on. do you know how to remove it? i removed 1 bolt on top and the haynes manual says theres 1 on the bottom but i dont see it. any advice?? |
05-22-2007, 07:04 PM | #300 | ||
Be careful putting the valve cover back on, the screws are really easy to cross thread if you try and drive them in without turning them carefully in by hand at least 2-3 threads.. I cross threaded the screw under the passenger strut mount and thought I was screwed (no pun intended). Luckly I only buggered up 1 or 2 threads before I stopped and backed off. Had to get a 6mm X 1mm tap and clean up the threads. If you want to save a little time the 4 push rods in the corners don't have to come off, they go underneath the gaskets. Most of the rest go over or through the gasket and need to come out. Sparky |
