Go Back   Automotive Forums .com Car Chat > Oldsmobile > Achieva
Old 11-05-2006, 11:46 AM   #1
57ChevyMan
94 Achieva engine fan continues to run.
Engine fan continues to run after engine is shut off, even when engine is cold. Initially had problems with overheating and now this. Fan runs until it runs the new battery down. Suspect temp sensor but not sure. Also, where is the temp sensor located and how hard/easy is it to change. Thanks
57ChevyMan is offline   Reply With Quote
Old 11-07-2006, 10:07 AM   #2
BNaylor
BNaylor's Avatar
Re: 94 Achieva engine fan continues to run.
Just follow the upper radiator hose to the thermostat. The ECT sensor should be located below the thermostat housing on the lower intake manifold. Another possibility would be the ECM module.
Welcome to AF.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 11-08-2006, 06:55 PM   #3
57ChevyMan
That raises additional questions. I removed the air filter cover and the air intake hose and there are what appears to be two sending units at the thermostat housing. I disconnected the wire from the sending unit that is furthest from the drivers side and that disabled my temp guage but the fan still runs.
1. Does the ECT control the fan and the temp guage?
2. If I unplug the wire(s) from the ECT, should the fan run all the time or not at all?
3. What is the sending unit closest to the drivers side ?
4. Where is the ECM and what does it look like?
Thanks
Old 11-17-2006, 11:43 AM   #4
randy78
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
if it were mine i would go witha new fan temp switch first
or test it with multimeter
i dont know what the specs would be on it without a manual
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
randy78 is offline   Reply With Quote
Old 12-30-2006, 09:51 PM   #5
Raymond4646
I would also look into the possibility of a stuck relay.
Raymond4646 is offline   Reply With Quote
