Old 02-05-2014, 04:36 PM   #1
bradfordian
priming metal/pe
Alclad or zero paints primer/microfiller ok for model factory hiro metal kits?
bradfordian is offline   Reply With Quote
Old 02-05-2014, 05:06 PM   #2
freakray
AF Modelrater
Re: priming metal/pe
yes
AF User Guidelines
freakray is offline   Reply With Quote
The Following User Says Thank You to freakray For This Useful Post:
bradfordian (02-05-2014)
Old 02-06-2014, 11:31 AM   #3
CrateCruncher
CrateCruncher's Avatar
I like to use Tamiya Metal Primer before laying down my main primer. It's clear and has a chemical reaction with the metal that helps it adhere to photo-etch, white metal and wire. I even decant some from the can into a small paint jar for brushing onto little parts. If you decant into a jar make sure the propellant has finished outgassing before tightening the lid (24 hours) so you don't risk an explosion.
http://www.amazon.com/Tamiya-87061-000-Metal-Primer-Spray/dp/B000BN9R1E
When I first started building metal kits I didn't know about this undercoating and some of my paint jobs started flaking off.
CrateCruncher is offline   Reply With Quote
Old 02-06-2014, 11:54 AM   #4
freakray
AF Modelrater
Not sure how readily available the clear metal primer from Tamiya is, the last few times I've tried to get it I have been told it's 'discontinued'. Tamiya does have a gray metal and plastic primer which works fine thought.
AF User Guidelines
Old 02-06-2014, 08:00 PM   #5
RonCla
RonCla's Avatar
I've always used Automotive Self Etching Primer. its a fraction of the cost of Tamiya Metal Primer down this neck of the woods
RonCla is offline   Reply With Quote
