| Latest | 0 Rplys |
View Poll Results: WRX= Twin Turbo? | |||
Yes | 7 | 6.60% | |
No | 99 | 93.40% | |
Voters: 106. You may not vote on this poll |
11-01-2002, 04:40 AM | #46 | |
When did I say the Vortech charger was a turbocharger?
11-01-2002, 05:00 AM | #47 | |
supercharger's have three types- roots, centrifugal, twin-screw
Roots are positive displacemente units, which means every rev of the blower pumps out a fixed volume of air, regardless of the blower's rpm. Result is that boost comes on early. Most application produce full boost at 2000-2500rpm. Boost can be altered by changing pulley size. Best to underdrive larger unit than to overdrive smaller one. Manufacturers of this product include B&M, Littlefield, Sebring. then you have Centrifugal the most popular type for fuel injected engines. this sys. Provides airflow proportional to blower rpm, thus full boost comes as high rpm. Manufacturers include Accessible Technologies, B&M, Nelson, Paxton, (Vortech) next we have twin-screw positive displacement, similar to roots. the differences are it uses twin screws instead of lobed rotos to compress air, works best when overdriven. Sample of those are Whipple Industries. (Lysholm screw Supercharger) a Lysholm supercharger looks similar to a helical Roots blower, but with rotors that are far more twisted, and have a conical taper. The result is that these "screw-type" compressors have an internal compression ratio, making them more efficient in high-boot applications. One disadvantage of this internal compression ratio is higher parasitic losses during off-boost operation (and engine strain). |
11-01-2002, 05:03 AM | #48 | ||
11-01-2002, 05:05 AM | #49 | |
You still didn't answer my question
11-01-2002, 05:08 AM | #50 | ||
11-01-2002, 05:10 AM | #51 | |
I said the Vortech charger is basically a belt driven turbocharger, not a turbocharger.
And I must say I admire your copy&pase skills, you rock! |
11-01-2002, 05:19 AM | #52 | ||
11-01-2002, 05:38 AM | #53 | |
Its a single turbo, and deakins learn the diffrence between a supercharger and a turbocharger. they are NOT the same, the only thing that is the same is that they both spool a turbine.
mods- aem intake eibach sportline springs thermal r&d exhaust cat back skunk2 mCLV |
11-01-2002, 05:41 AM | #54 | ||||
And you are a mechanical engineering major. http://www.miata.net/garage/turbos.html "3 basic styles: roots, centrifugal, twin-screw Roots: positive displacemente units, which means every rev of the blower pumps out a fixed volume of air, regardless of the blower's rpm. Result is that boost comes on early. Most application produce full boost at 2000-2500rpm. Boost can be altered by changing pulley size. Best to underdrive larger unit than to overdrive smaller one. Manufacturers include B&M, Littlefield, Sebring. Centrifugal: Most popular type for fuel injected engines. Provides airflow proportional to blower rpm, thus full boost comes as high rpm. Manufacturers include Accessible Technologies, B&M, Nelson, Paxton, Vortech. Twin-screw: positive displacement, similar to roots. differences: uses twin screws instead of lobed rotos to compress air, works best when overdriven. Sample manufacturer: Whipple Industries." http://www.sportcompactcarweb.com/tech/0107scc_garage/ "The Lysholm supercharger looks similar to a helical Roots blower, but with rotors that are far more twisted, and have a conical taper. The result is that these "screw-type" compressors have an internal compression ratio, making them more efficient in high-boot applications. One disadvantage of this internal compression ratio is higher parasitic losses during off-boost operation." |
11-01-2002, 05:41 AM | #55 | ||
11-01-2002, 05:44 AM | #56 | ||
11-01-2002, 05:51 AM | #57 | ||
11-01-2002, 05:57 AM | #58 | ||
Ignorance more frequently begets confidence than does knowledge: it is those who know little, and not those who know much, who so positively assert that this or that problem will never be solved by science. |
11-01-2002, 06:14 AM | #59 | |
omg! A Berkeley professor saying all superchargers have turbines?
11-01-2002, 06:26 AM | #60 | ||
