05-18-2012, 12:43 PM | #46 | ||
Re: 2000 Camry V-6 LE abnormal tire wear
Axles don't last that long. Even if the boots aren't split, they are worn out and causing vibration when driving down the highway. |
05-18-2012, 09:57 PM | #47 | ||
It was at a Chevy house. afterwards I 1st went to the man that did it, he acted as if I was nuts. Them I went to the service manger, he was not happy, & quickly he had the problem fixed, them taking it for a test drive. Them told me, it seems to steer perfectly, yet if you have any problem, get back to me, I will take care of it. Thankfully it was A OK! Some people are just dense!
Have a great day, Jerry 1992 Chevy S-10 Blazer 4 X 4, 4.3 W engine 3.42 gears 172,000 & still going Sold 2010 Toyota Tacoma Double Cab 4X4 V6 4.0 V6 DOHC 24V VVT-i 236HP Engine 12,000 plus miles Bought 10-22-11-2001 Toyota Camry LE SuperWhite 4 Door sedan I-4 89,680 miles |
05-23-2012, 12:55 PM | #48 | ||
05-24-2012, 04:09 PM | #49 | |
Has this car ever been in a bad wreck warping its body or uni-frame, or whatever they call it nowadays? If so that might explain a proper aliment, yet still wearing tires & pulling to one side.
05-24-2012, 04:31 PM | #50 | |
The car has never been in a wreck. It was purchased new by my dad and was given to me when he got a new car.
05-24-2012, 07:29 PM | #51 | ||
Glad yours has not.
06-09-2012, 07:47 PM | #52 | |
Here are the before & after alignment settings from the most recent alignment. It was out of spec due to the replacement of suspension parts (tie rod ends, ball joints, etc). I have the alignment readings from one other alignment that I will try to get posted as soon as I find it.
http://i1073.photobucket.com/albums/...Alignment4.jpg |
01-28-2013, 06:30 PM | #53 | |
Two of the General Altimax HPs finally wore out with 44,000 miles on them (they are a 55,000 mile tire). I bought a couple of slightly used Yokohama Avid S tires and had them mounted on the front. PULL IS GONE!
I replaced the rear tires with a couple of used Firestones. Still drives good. Tire wear is now ok on all four tires. I am stunned that I had 10 different tires that pulled to the left (1 set of Toyo Spectrums, 1 set of General Altimax HPs and 2 Wilson tires). Is it possible that the Toyos and Generals, which are performance tires, have greater rolling resistance and therefore create a pull? The car was probably engineered with common all-season radials in mind. Two bad sets of tires??? Anyone have any theories? |
The Following User Says Thank You to hotpursuit For This Useful Post: |
Brian R. (05-16-2013)
05-16-2013, 09:06 AM | #54 | |
Resident Chemist
It might have been that one of your wheels had a problem which prevented that tire from mounting correctly or lost air pressure much faster than the others (something in the bead?). Anyway, it may have resolved itself. Good luck.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html "What we've got here is a failure to communicate" |
