| Latest | 0 Rplys |
09-06-2008, 05:14 PM | #16 | ||
Re: Tranny fluid low and rough shifting?
To start no one said they could not be mixed but technically they should not be mixed for obvious and sound reasons. From what I can see you did not read my whole post (#12) to include the note at the bottom after the pic. Obviously if you do a DIY pan drop service not a flush and decide to switch over to Dex VI there will be residual Dex III. But I'd rather have 80% Dexron VI versus 80% Dexron III or some other weird mix in my autotransaxle(s). Otherwise why switch over. All the Dexron III will do by mixing disproportionally is dilute or reduce the capability of the new Dexron VI which is clearly a superior product. What GM cars do you own with a 4T65E autotransaxle? You know the one subject to all the problems or issues. Most of us that own GM cars with the 4T65E or 4T65E-HD versions are not willing to take any chances but would rather do the job properly. Some may even take it to a GM dealer and have a fluid exchange type flush done but is that improper? I have three GM cars with this specific autotransaxle, over 10 years experience with them and know better. Better safe than sorry. Additionally, you failed to answer my question. I don't care about your personal experiences or how you interpreted what the container said but asked you the following below or to disprove my opinion. What I am looking out for is the welfare of our AF community and ensuring they get reasonable or proper advice. A lot of that is based on common sense and sound maintenance not what some container tells you since obviously those companies will not be paying for any possible damage that could occur. It would be sad and reckless to tell them to go ahead and mix the two without any clarification and you will be just fine. "Show me where it says mixing the two is recommended or an acceptable practice and there will be no future issues including liability." You failed to do that. Not only is it my opinion but has been a general concensus of the automotive on-line community for years since 2005 when we first starting discussing Dexron VI. Anecdotal but it supports my position. See links below. Click here Click here
09-07-2008, 10:20 AM | #17 | |
[quote=BNaylor]
To start no one said they could not be mixed but technically they should not be mixed for obvious and sound reasons. From what I can see you did not read my whole post (#12) to include the note at the bottom after the pic. Obviously if you do a DIY pan drop service not a flush and decide to switch over to Dex VI there will be residual Dex III. But I'd rather have 80% Dexron VI versus 80% Dexron III or some other weird mix in my autotransaxle(s). Otherwise why switch over. All the Dexron III will do by mixing disproportionally is dilute or reduce the capability of the new Dexron VI which is clearly a superior product. I agree with you ,,,as this is my opinion on transmission fluid servicing , "that all the fluid being removed and replaced is the best method to ensure transmission life/performance" ... what I don't agree is, "that you believe your opinon and knowledge is superior to what the fluid manufacturer recommends'' , as to its compatibility...... If it were as you stated a must do proceedure "replace all fluid" MR. GM would have supplied the vehicle with a method to safely remove all of the old fluid ... like how about a toque converter drain plug???? so owners now get the transmission flushed at the GM dealership at the recommended interval of 100,000mi and soon find disaster... If these transmissions are so fragile or abused the owners must use common sense and simply do frequent fluid changes and not wait until the fluid looks smells/ bad ... and never ever use the flush proceedure .. now thats my opinion totally.. as far as warantee of the product fluid used.. you know that no company will guarrantee this ...even the vehicles we buy new from GM its a battle to get repaired under warrantee .... simply stated just because your changing over to the new Dextron VI from the older dextron III ,,as written on the container from the fluid manufacturer it is compatible and is not an issue .. |
09-07-2008, 05:40 PM | #18 | ||||||
So you agree with me in part but disagree. Careful j cAT. Like some of your other posts in this forum that is starting to sound like a personal attack. My opinion is based on erring on the side of caution. What really counts is what GM says and not the fluid manufacturer or any misinterpretations of some ambiguous label. GM only specifies and licenses the Dex VI specifications. They do not make or produce any of the Dexron VI ATF on the market. Quote:
Click here Quote:
09-07-2008, 07:43 PM | #19 | ||
THE FLUSHING MACHINE :IS A DEVICE USED BY DEALERS TO DESTROY YOUR TRANSMISSION.....STAY AWAY!!! On your question concerning my vehicles ....as you know I did not list a vehicle that has this 4l65 tranny but my daughter does ... this vehicle has over 100,000mi and the fluid/filter is replaced every 40,ooomi...so far no transmission problems ....and NO FLUSHING... dealerships should only be used as a last resort to repair/service common vehicle maintenence....TOO EXPENSIVE... also I have never attacked anyone on these forums ,, and if I offended you ,, because you have a extreme view concerning this trans fluid so what, I don't care....let the readers decide....I read the instructions and make judgments based on data and facts...not what repair tech's THINK is best.. for some reason this tranmission fluid maintenence is a very sensitive issue to many on these forums. perhaps dealer tech's need to get these machines to start making some revenue... |
09-07-2008, 08:14 PM | #20 | ||
You just made this an issue for the Moderating staff to decide. A PM message will be forthcoming. This thread has been closed from any further posting.
