Old 07-25-2014, 07:46 PM   #1
ataschner
ataschner's Avatar
Jaguar XJR9 LM. What is this part???
Hi people. Does anybody know what is this part? Any more pictures or reference about it?
Already googled but unfortunately no good results
It is located inside a sort of bay on upper side of the gear box.
Thanks guys!
SeeYa!
Drago
http://www.small-dreams.com/forum
ataschner is offline   Reply With Quote
Old 07-25-2014, 08:44 PM   #2
freakray
AF Modelrater
Re: Jaguar XJR9 LM. What is this part???
As best as I've ever been able to tell looking at photos and cutaways, it's part of the shift linkage going across the top of the differential to the gearbox.
AF User Guidelines
freakray is offline   Reply With Quote
The Following User Says Thank You to freakray For This Useful Post:
ataschner (07-28-2014)
Old 07-25-2014, 09:54 PM   #3
Fangi0
It appears to have a bleed nipple on it... My guess is the clutch slave cylinder
Fangi0 is offline   Reply With Quote
The Following User Says Thank You to Fangi0 For This Useful Post:
Old 07-25-2014, 11:27 PM   #4
icon_modeler
You must be confused with the XJR-14 which had the gear linkage in the valley of the Cosworth/Jaguar HB V-8.
This picture is of the XJR-9 same as an XJR-6, XJR-8 & XJR-12. The part in questions is the slave cylinder as already suggested. The shift linkage can be seen lower running under the top wishbone. You can make out the orange donut of the universal joint in the linkage just in front of the rear leg of the wishbone.
Basically this is what you are looking at, a Girling Slave Cylinder. It looks as though the fitting arrangement has been swapped but that is not uncommon with this type of cylinder.
This is an XJR-8
This is of the LeMans Winner from 1990 when it was being built up at TWR/USA in Valparaiso Indiana when I worked there I took these with a point and shot disposable Kodak Camera, sorry for the picture quality
This is also an XJR-9
And these are of an XJR-12
More pictures can be found here:
http://s601.photobucket.com/user/dtc...?sort=3&page=1
I hope this helps!!
icon_modeler is offline   Reply With Quote
The Following User Says Thank You to icon_modeler For This Useful Post:
Old 07-27-2014, 04:29 PM   #5
rgriffs
thanks for sharing your photos, sure they will help all of us contemplating that kit again.
rgriffs is offline   Reply With Quote
Old 07-28-2014, 08:21 PM   #6
ataschner
ataschner's Avatar
Holy S***
I don't have words to describe how grateful I´m!!!!
Thank you so much for the help and for the photos!!!!
It sure will help a lot of modelers
SeeYa!
Drago
