Go Back   Automotive Forums .com Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 11-01-2005, 04:39 PM   #1
butzebmw
Send a message via MSN to butzebmw
Question 1994 Jag xj6 vdp Fuel pump? starting problems
I have a 94 xj6 and it seems to maybe have a fuel pump problem im not sure. once it runs it runs great, but to get it started I have to turn on the key let it sit for a few seconds and then do it again sometimes ill here the fuel pump sometimes not. after i hear it kick in it starts right up does this mean I need a new fuel pump? or are the connecters just coroded? or is it something else? ive called jaguar and they said it could be a relay? how do I test that and where is the in tank fuel pump on this car i took the trunk carpet out and could see the tank but no pump. anyone know where this is at? thanks!
Nick
butzebmw is offline   Reply With Quote
Old 11-25-2005, 10:44 AM   #2
DieInterim
Re: 1994 Jag xj6 vdp Fuel pump? starting problems
Nick
Swap relays with another from your car. You might also have a bad check valve in the fuel system allowing drainback. How's the fuel filter?
Blake
DieInterim is offline   Reply With Quote
Old 04-27-2006, 10:54 AM   #3
GEORGE IYUT
I Have A 94 Xj6 Died When My Son Drove It With A No Start Problem, I Have Replaced The Fuel Filter & Plugs. Tried To Start It No Go, I Can Smell Fuel From The Tail Pipe, I Assume Fuel Gets Into The Cylinders, Could It Be A Another Problem. Please Help. Thanks
GEORGE IYUT is offline   Reply With Quote
Old 05-23-2007, 09:37 PM   #4
satterfield5
George or anyone:
I too have a 1994 Jaguar XJ6 with a starting problem. There seems to be no ground to the starter relay. I can ground the starter relay and it'll start. There's about 6 wires coming out the relay. Did you ever fix your problem?
satterfield5 is offline   Reply With Quote
Old 05-31-2007, 09:35 AM   #5
redmansioner
Banned
Have you tried if your spark plugs are okay?But take a closer attention on the relay.My Jaqguar once have problem in starting problems but This type on mine was a worn out spark plug,but the connectors arwe also checked by the dealer and I have also changed the jaguar struts cause i notice it was also affecting the fuel consumption.My car was not running smoothly back then.
redmansioner is offline   Reply With Quote
Old 07-26-2008, 12:04 AM   #6
djagman
the pump is under the car just infront of the drivers rear tire.give it a tap with a small hammer.and lsten to it to see if it changes tone.that year has a nasty habit of letting water in past the fill cap so do a fuel sample test.and ofcourse check the fuel filter.it is right buy the pump.just remove and blow through it.or replace.you choice.
djagman is offline   Reply With Quote
Old 07-26-2008, 12:36 AM   #7
'97ventureowner
'97ventureowner's Avatar
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline   Reply With Quote
