| Latest | 0 Rplys |
Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
08-20-2007, 11:05 PM | #61 | ||
Re: 4.3w low power
5693dtcd |
08-29-2007, 10:11 PM | #62 | |
Re: 4.3w low power
Hey there everyone-
I was unable to do an injector balance test. From some of the techs I talked to and the miles on the vehicle I went ahead and replaced the injector "spider " assy. i came away with a very slight improvement. I hooked it up to a scanner and the timing still retards. I work at a medium duty GMC dealer. I was able to look up on the computer, per VIN, a module located inside the VCM. It is called a Knock sensor module, p/n 16208961. If this is bad- would it cause the timing to retard? Let me know if you have ever seen this problem. Thanks
5693dtcd |
08-30-2007, 08:45 AM | #63 | ||
AF - Advisor
Re: 4.3w low power
The knock sensor module picks up the knock sensor signal and can and should retard the timing if a knock is present. You might try and unplug the knock sensor and see what it does. Check actual engine timing with a timing light and see if it matches the VCM/pcm readings. The VCM gets it timing reference from the crankskaft sensor. You might want to check it real close to. If you have a lab scope it works goos on checking sensors. But also remember the camshaft retard setting has nothing to do with the actual engine timing. It only centers the dist rotor to fire direct on the plug wire terminal. Is there any VCM reflashes out for your truck or tsb on it? Good luck. MT
08-30-2007, 09:54 PM | #64 | ||
Re: 4.3w low power
The only reason I havnt looked at it before is when I checked it with the scanner the voltage fluctuated indicating it was working. If it runs great with it unplugged, do I need a new sensor or module? Other than a new computer that's the only thing that retards the timing, I think. I'll checkthe crank sensor sometime also. I'm taking it easy this weekend though. I'll check it next week. Have a good Labor Day Weekend!!
5693dtcd |
09-05-2007, 10:10 PM | #65 | |
Re: 4.3w low power
The check engine light came on over the weekend. I have a code P0420 for a catalyst efficiency low on bank 1.
I also have a code P0304 misfire on number 4. The code P0420 is what has me concerned. What would cause a this code?
5693dtcd |
09-06-2007, 08:55 AM | #66 | ||
AF - Advisor
Re: 4.3w low power
Fix missfire and engine running problems first. Then clear codes and see if 420 or any other codes come back. MT
09-10-2007, 08:46 PM | #67 | ||
Re: 4.3w low power
I've been told that if the cranksensor was bad, it would have a hard start or no start condition. It starts good. Thanks.
5693dtcd |
09-10-2007, 10:25 PM | #68 | |
Re: 4.3w low power
i would start looking at the computer if you can find a another blazer or jimmy with the same year and drive train you could try the comp out of that if you can find and owner one willing to help you
09-10-2007, 10:38 PM | #69 | |
Re: 4.3w low power
also your readings from the scanner with the throtel at 59% eng load should be higher than 25% i think the comp uses the maf senser to no the eng load
MAF gm/sec 43.68 seems high for only 25% load I threw a code today coming home. P0101 Mass Air circuit out of range. I did a freeze frame on the scanner and received the following readings Eng. load 25% Coolant 149 ST Trim 185 ST trim % 44.5 LT Trim 138 LT Trim % 7.8 ST Trim 2 % -24.2 LT Trim 2 % 0 MAP 29.3 RPM 2306 Veh spd 52 mph MAF gm/sec 43.68 TPS 59% |
09-18-2007, 09:21 PM | #70 | ||
Re: 4.3w low power
5693dtcd |
09-18-2007, 09:25 PM | #71 | ||
Re: 4.3w low power
Thanks
5693dtcd |
09-20-2007, 10:58 PM | #72 | |
Re: 4.3w low power
with a scanner with live data drive and see what your knock retard is and what your ignition advance is. it should advance as far as 45 degrees at times at least thats what mine does and it runs real strong. also watch what it does when you first hit the gas you really should not see any retard i have a live data scan gauge and the only time i see it retard in the timing is when towing and pulling a hill and it starts to ping on gas post back wat you record. also have you checked your tps
09-22-2007, 07:13 AM | #73 | ||
Re: 4.3w low power
I've had it to two dealers. One was wrong. The other looked at it for 3 or 4 hours. When he told me whatever it is it wont be fixed today I told him to stop what youre doing. I cant afford that kind of comment. I work at a heavy duty truck dealer so I know about diesels and am mechanically inclined. I can do research and install parts myself. This has got me though.
5693dtcd |
09-22-2007, 07:16 AM | #74 | ||
Re: 4.3w low power
When it's fixed I'll post what was wrong. Thanks for reply
5693dtcd |
09-22-2007, 11:11 AM | #75 | |
Registered Offender
Re: 4.3w low power
I must have missed something... What year is the truck? That will make a difference, since the ECM/PCM would be different, and the control scheme would be different.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
