Old 02-01-2003, 06:26 PM   #1
Blowncivic1320
Blowncivic1320's Avatar
I need help with a mod on my MR-2
I have a fujimi SW20 mr-2 kit and want to make the little snorkel for air-intake to the engine (see pic below) and want to kno if any of you have done it or have an idea of how i can do it?
-Andrew-
Blowncivic1320 is offline   Reply With Quote
Old 02-01-2003, 06:40 PM   #2
Blowncivic1320
Anyone?
-Andrew-
Old 02-01-2003, 06:58 PM   #3
clatescivicr
Calm down its only been 15 mins! You need to have more patience....
But my guess would be is to take a straw and flatten it out a little...
Clate - I'm back
clatescivicr is offline   Reply With Quote
Old 02-01-2003, 07:27 PM   #4
integra818
integra818's Avatar
Send a message via AIM to integra818 Send a message via Yahoo to integra818
http://www.spoilers.com/accesscustom/toymr290.htm
It's gonna be hard to make, I don't know what you can base it off of, I guess you have to start with a blob of putty and start molding. It's not the scoop mouth that's gonn be the hard part, the hard part is where it goes nest to the engine covor (hood or trunk, whatever it is)
Off topic: my brother had one of those on his Mr2, whenever someone asked "what is it?" He replied, "it's a rocket launcer"
integra818 is offline   Reply With Quote
Old 02-01-2003, 07:30 PM   #5
Blowncivic1320
good suggestion but i was tryin to not use bondo...it is painted gunmetal already and i dont wanna have to sand and paint again (have already had to strip the car like 2 times) maybe i will try the straw idea
off-topic
that sounds funny...i mite do that someday...:angel:
-Andrew-
Old 02-01-2003, 09:15 PM   #6
hirofkd
hirofkd's Avatar
You don't have to apply putty directly on the body. Make the piece, paint and glue it on.
That would be a good aftermarket part, isn't it? Perhaps, I should make one and sell it.
Anyway, you can make a section cut of the inlet, wrap it with a strip of plastic sheet to make the mouth. Then, add the bone of the back part from a plastic rod or plastic sheet, and use epoxy or polyester putty to build the basic shape. Then file and sand to the desired shape.
Hiroaki Fukuda
hirofkd is offline   Reply With Quote
Old 02-02-2003, 05:26 AM   #7
flyonthewall
Car Mod guy
flyonthewall's Avatar
I shall need to make one of these when i do my TRD transkit. I would suggest making one from a 'sandwich' of styrene, similar to how you would make the hull of a simple model boat from a sandwich of wood.
flyonthewall is offline   Reply With Quote
Old 02-02-2003, 08:56 AM   #8
Blowncivic1320
Where can i get this styrene you are speaking of?
but the ideas sound like they could work but flyonthewall how would i get the putty to stay where i want it to while it is dryin so it goes in the basic shape?
-Andrew-
Old 02-02-2003, 11:57 AM   #9
Integra14
Integra14's Avatar
Send a message via AIM to Integra14
i think that a straw might work easier, clatecivic...., but fly on the walls might look better..
Integra14 is offline   Reply With Quote
Old 02-02-2003, 12:02 PM   #10
clatescivicr
Honestly, I would have to see it from a rear view to see how it really connects. I've never seen it before, or atleast I can't remember seeing it. To me it looks way out of place...
Clate - I'm back
Old 02-02-2003, 12:54 PM   #11
hirofkd
hirofkd's Avatar
Hiroaki Fukuda
Old 02-02-2003, 01:02 PM   #12
clatescivicr
wow that looks out of place! lol
I hope it really increases power...
Clate - I'm back
Old 02-02-2003, 02:31 PM   #13
Blowncivic1320
GRRRR...I WANT TO MAKE ONE SO BAD...the straw idea dont really work...
-Andrew-
Old 02-02-2003, 02:36 PM   #14
clatescivicr
Yeah the straw idea won't work after seeing the back. I know I would have to mold that piece on....looks like your going to have to repaint the body...
Clate - I'm back
Old 02-02-2003, 03:29 PM   #15
hirofkd
hirofkd's Avatar
No need to, because you don't have to directly build this on the painted body.
Can you visualize flat planes like these?
There are four planes that can be made from plastic sheet. Once, you get the base part done, make the inlet with a strip of plastic, and use epoxy putty to make the rest of the top part.
Hiroaki Fukuda
