Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 11-12-2005, 01:20 AM   #46
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: Camry FAQs and Information
TOYOTA PARTS CATALOGS
Thanks to SidneyCanada for the following post:
There are several free online Toyota EPC catalogs that you can download that are amazing and I use them all of the time prior to a repair or when trying to cross reference parts:
Here is a post fellow poster (Todd) who posted it on another 4-Runner/Pickup discussion site about 4 years ago:
"There is a newer version of the EPC available for download.
Similar in size to the older version (254MB and 220MB zipped files)
I have them on my personal FTP server (not always running), and they are also on another FTP server.
Address and login for mine:
151.203.109.45 Port 21
Login: t4x4pickup
Password: t4x4pickup
Address and login for the other (usually running 24/7)
ftp.lawvision.net
User: upload
Pass: upload
Apparently they cover 1988 and up vehicles (I haven't unzipped mine yet).
Feel free to upload and download on mine.
Enjoy!
Todd E:zoddoo@hotmail.com"
Here are other places to download the free Toyota EPC catalogs:
http://www.yankeetoys.org/docs.htm
http://oldschool.supracentral.com/htm/epc.htm
http://turbosupras.com/pages/en/pages/technical/epc.htm
http://www.showmesome.info/hilux/inf...load_links.htm
http://www.speedtoys.com/%7Earnout
http://www.speedtoys.com/~gemohler/epc
http://membres.lycos.fr/doc4toy4u/se...EPC_TOYOTA.zip
http://thepiratebay.org/details.php?id=3355606 (DVD)
For version 1/2002 the passwords are:
Europe 02052311
General 02032511
U.S.A. 02022608
Japan 02071608
Here’s the codes for the 01/2002 disks:
Europe 02022004
General 02022212
U.S.A. 02022608
Japan 01121209
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline
Old 01-03-2006, 03:24 PM   #47
Brian R.
Resident Chemist
Brian R.'s Avatar
Torque Specifications
Q: I need torque specifications for the bolts in my 1988 Camry. Where can I find this information?
A: The torque specifications for bolts/fasteners in any Camry engine can be found at:
http://www.autozone.com/autozone/rep...ationsMain.jsp
Brian R. is offline
Old 01-03-2006, 03:29 PM   #48
Brian R.
Resident Chemist
Brian R.'s Avatar
Troubleshooting Camry Engine Mechanical Problems and Engine Performance Problems
Q: Where can I find a troubleshooting guide for my Camry engine?
A: A guide for troubleshooting Camry engine mechanical problems and engine performance problems can be found at Autozone:
http://www.autozone.com/autozone/rep...roubleShooting
Brian R. is offline
Old 02-25-2006, 02:31 PM   #49
Brian R.
Resident Chemist
Brian R.'s Avatar
TURBOCHARGING A 2.2-L 5S-FE
Modifying your 5S-FE
There are a lot of nay-sayers out there that say the 5S-FE motor is a weak non-performance economy motor and can't handle the boost. I don't agree with this assumption and feel that many setups are not so much limited by the motor itself but by their owner's understanding of how it works. The 5S-FE like any other motor has it weaknesses and strengths but overall is a very sturdy platform for modification. When planning modifications to a motor, I believe it should be thought of as a series of obstacles to be overcome. As you remove one big obstacle you find yourself facing another one but in general the overall system will become more efficient. In addition, upgrading one component can overstress another that was within its operating limits before the upgrade. To safely build a performance motor you need to understand what the limits of your motor are so you can know how far to push the envelope and what components need to work together to get the desired result. Here are some of the limits of the 5S-FE platform as I see them.
Basic Strengths of the 5sfe:
- Solid block - High powered 500+rwhp MR2s often use these blocks.
- Stroked crank - The 5S-FE is a stroker motor from the factory. Also used in 500+rwhp MR2s.
- Displacement - 2.164 liters which is great for spooling a turbo.
- Long intake runners - Although bad for high revs this gives more velocity for torque down low.
- 9.5:1 compression - Good for NA power and low boost power but limits the maximum boost.
- Fuel rail - The fuel rail on the 5S-FE is a top feed rail which is capable of supporting 850cc injectors or maybe larger
Limitations:
- 6300rpm redline - Valve springs and connecting rod bolts are not strong enough to be reliable past this.
- Short duration cams - ~220? and 8mm lift. The 3S-GTE has 236 advertised duration and 8.5mm lift.
- Small valves - 32.5mm intake and 28mm exhaust. The 3S-GTE has 33.5mm and 29mm exhaust.
- Linked intake and exhaust cams - There is a drive gear that keeps them synced so an adjustable cam gear can only be put on the intake cam and it also affects the exhaust.
- Fuel pump - Only good to ~235rwhp at stock pressure.
- 5S-FE Computer - Runs rich and is made for the stock NA injectors.
- Injectors - Made for max 150rwhp maybe less. 91-92 injectors are 205cc (yellow) and 93+ are 225cc (Dark green).
- Intake manifold - I don't know the limits of the 5S-FE intake manifold but most people shooting for high power replace it with a custom one. I suspect it would become a bottleneck in the 250-300rwhp range but that is just a guess.
- Throttlebody - I also don't know the limits of the stock throttlebody but it is only 2" in diameter which is rather small. I suspect the 5S-FE throttlebody will become a major bottleneck at 200-250rwhp depending on the boost level. Again this is just a guess.
What can you expect from your turbo 5S-FE?
A stock 5S-FE in good condition will easily handle boost of up to 9-10psi with as much as 180rwhp. An MR2 with a 5S-FTE is an absolute blast to drive and is a little faster then a stock turbo MR2. There is a misconception that the S54 transmission in the NA MR2 has shorter gears then an E153 turbo transmission. It is partially true but only the 4th and 5th gears are shorter. 1st through 3rd are almost identical when factoring in final drive gears. So why is a 5S-FTE MR2 faster? Because the turbo spools faster, the compression is higher and it's a bigger engine.
The simplest, bare minimum setup for a 5S-FTE includes the following:
- Factory 3s-gte Turbo CT26 with wastegate actuator
- Factory 3s-gte Elbow and Primary Catalytic converter
- Factory 3s-gte Exhaust Manifold
- Factory 3s-gte Intercooler w/ fan
- Factory 3s-gte Oil Pan
- Factory 3s-gte Oil/Water Coolant Lines to and from Turbo w/oil drain hose and clamps
- Factory 3s-gte turbo to intercooler Pipe
- Custom intercooler to throttlebody pipe (mine is 2.5" diameter)
- Factory 3s-gte Blow Off Valve with the VTV valve
- 4 MkIII Supra NA 315cc Injectors (light green top) part # 23250-70080
- 4 NGK BKR6E or BKR7E Spark Plugs (BKR7E is the colder plug for higher boost)
- Factory 3s-gte 2bar MAP Sensor part # 89420-17030
- 30 amp relay for intercooler fan
- Boost Gauge
- MSD-BTM # 5462
- MSD Tach Adapter #8910eis
- Oil and water send/return fittings (Other ways possible using JIC and AN fittings)
Oil
1/8 BSPT to 1/8 NPT male to male
1/8 NPT female T
1/8 NPT to 3/8 barbed hose
1/8 NPT to female 1/8 BSPT
Water
Coolant Gooseneck from a 91 NA MR2
M16x1.5 to 3/8 NPT (I had to buy a M16x1.5 to 1/8, drill and tap it to 3/8)
3/8 male BSPT to 3/8 female NPT
2 - 3/8 NPT to 3/8 hose barb 90 degree bends
- 6 3/8" hose clamps
- Misc nuts and bolts for the turbo and manifold if you are missing any
- gaskets - Turbo to downpipe and exhaust manifold
- Misc Hoses and clamps
Hoses
12"long x 2"diam hose (IC pipe to IC)
2"diam coupler (Turbo to IC pipe)
2-2.5"diam transition coupler (IC to TB pipe)
2.5"diam coupler (TB pipe to TB)
Clamps
2 2.25" clamps
3 2.5" clamps
3 2.75" clamps
- 4 feet 3/8" oil/coolant hose
- 10 feet 5/32" vacuum hose
- 18 gauge wire and crimp connectors
- 2 1/8" exhaust pipe coupler and two pipe clamps to join the down pipe to the NA exhaust
- Zip ties and misc hose clamps to secure vacuum lines under boost.
Upgrades from the basic 5S-FTE could include:
- KO or other Downpipe
- Turbo exhaust system
- Boost Controller
- EGT Gauge
- Air/Fuel Ratio Gauge (Modify for WOT reading from www.gadgetseller.com)
- Oil Pressure Gauge
- Oil Temp Gauge
- Pillar pod and/or steering column pod
- SPAL intercooler pull fan
- Silicon hoses for turbo/IC pipes
- T-Bolt clamps instead of screw type clamps
- SAFC with adjustable FPR for fuel tuning (Requires spending time on a dyno)
- J&S Safeguard instead of MSD-BTM
- SMT6 instead of MSD-BTM/SAFC (Requires spending time on a dyno)
- CT-20b or larger turbo. (Be very careful here. 9psi on a CT-26 is not the same as 9psi on a TD06. You'll need more fuel per pound of boost with a bigger turbo but you will get more power at lower boost.)
Many people ask if they can substitute different injectors or MAP sensors. The answer is yes but you will require some advanced way to tune your WOT fuel maps and it will get a whole lot more expensive. Call it the magic triangle of the 5S-FTE: 5S-FE Computer, 315cc injectors and 2 bar stock turbo MAP sensor. It's a balanced equation and anything else throws it off. The combination of CT-26, turbo MAP sensor, stock fuel pump, 315cc injectors and 5S-FE computer is only good up to about 10psi of boost. At this point the injectors are probably over 90% duty cycle because the ECU runs so rich. With some kind of fuel tuning you could possibly go higher but be careful, use a wideband and take slow steps up. If you go too lean you risk detonation and damaging your engine. Something else that is necessary to keep your motor safe is a device to retard timing according to boost level. You need this because you are tricking the stock ECU into thinking that less air is going into the engine and it advances timing past what is safe at boost. I chose to use the MSD-BTM and Tach Adapter because it was the most economical solution. A J&S Safeguard or SMT6 or SMT7 will also work but are more expensive with more features. Most people have it set to retard 1/5 to 1/2 degree per pound of boost. If you have a 93+ 5S-FE it will also have a knock sensor which is an added level of safety.
If 10psi and 180rwhp aren't enough for you then there is still hope. Toyota only planned for the 5S-FE to have 135hp at the crank but it is still the sister engine of the 3S-GTE and in some ways, as I mentioned above, the stronger of the two. All of the weaknesses of the 5S-FE can be overcome but not all of the solutions are cheap.
Here are some of the limits and what you can do to get past them:
- Cams - Webcams and others make cams that will increase duration and lift. Webcam grinds of 294, 577 and 101 should increase performance and still be streetable. Welded cams like Webcams are better then cams that are only ground because the base circle is kept the same so stock shims can be used. You will need an EMS to idle really aggressive cams like 256 degree and above. Remember that cams shift your torque curve to the right so buy cams to suite where you want your torque peak. An bad example would be buying 306 degree cams. They would be almost useless in a motor that has a 6300rpm redline. Also high lift or ground cams may require underbucket shims or shimless buckets to keep the shims from popping out. Just FYI the difference between 91-92 cams and 93+ cams is the diameter of the base circle and lobe size (smaller base circle on the 91-92 with narrower lobes). Otherwise they would be interchangable.
- Valves - 1mm or 2mm oversized valves will do wonders for volumeteric efficiency. 2mm oversized valves will require larger seats, porting and deshrouding of the combustion chamber. Use valves from a 3S-GTE for 91-92 5S-FE and valves from a 2JZ-GTE for the 93+ 5S-FE for 1mm oversized. The +1mm version of these valves will be +2mm in a 5S-FE.
- Ports - Port matching and cleaning up the intake and exhaust ports will improve VE and may be required to see gains from oversized valves. When porting you will always get the best results from a shop that can flow test the head. Many people recommend Chris Katthage of Engine Logics because he deals almost exclusively in MR2 performance motors and will document gains in flow when doing head work.
- Fuel Pump - Good to 235rwhp with stock pressure. Replace with a Walbro 255lph or supra pump if you want more.
- 5S-FE Computer - Runs rich and fires the injectors in batches. Also it can't idle a set of aggressive cams. Replace with a standalone or add an advanced piggyback. An SMT6 or SMT7 will allow you to get past your fuel and timing issues but still has limits. Personally I would go with stand alone ECU because it will remove all the limitations of the 5S-FE ECU.
- Injectors - With a standalone or advanced piggyback and a big fuel pump you can run much larger injectors. They may have to be custom though because top feed injectors are not as common as the side feed injectors found on the 3S-GTE.
- 6300rpm redline - To safely go above this you need upgraded valve springs (3S-GTE springs for 91/92 or 2JZ-GTE springs for 93+), forged or 3S-GTE rods because they will have bigger bolts (3S-GTE and 5S-FE rods are almost identical except for the rod bolts) and a stand alone computer to raise the rev limiter. 3S-GTE rods can be made to fit by grinding the crank journals down but they are also a few thousandths shorter then the 5S-FE rods so that can slightly lower compression.
- Compression - Custom Forged pistons can be installed for just about any compression ratio. Remember that overboring and oversized valves can change your compression ratio. For high boost you may want to shoot for 9.0:1 or less. Aggressive cams can also let you run higher compression and higher boost because with teh right tuning they reduce the propensity for detonation.
- Cam Gears - An adjustable intake cam gear can be made from a 2JZ-GTE adjustable cam gear with the center machined to fit. As for the exhaust, it will move with the intake in the same direction. This is probably the hardest limit to get past on a 5S-FE but it may be possible with some custom machine work to one of the internal cam gears to make it adjustable (Future project?).
- Intake Manifold - Just like any stock manifold there is only so much air that can flow through it and choosing the correct runner length and plenum volume in a custom manifold can add some extra velocity at different rpms and boost pressures. Most of the custom manifolds I have seen for the 5S-FE are side feed to keep air flow as even as possible between the cylinders.
- Throttlebody - You can use a Q45 or Mustang throttlebody to get a bigger bore and get more air flow. This requires a custom intake manifold and possibly some custom work for the throttle position sensor. With a stand alone this should be easier to get working.
- Oil Pump - Replace with a 98+ 5S-FE pump and shim the relief valve 1-1.5mm to get a higher pressure. If you do this you may have to put a restrictor on your turbo oil feed line to keep from blowing oil past your seals.
Credit where credit is due.
Much of the information on this page was mostly found on the MR2 Owner's Club Message Board at www.mr2oc.com. Specifically from the instructions on how to turbocharge a 5S-FE by Aaron Fowler who was one of the first to make it work. Other people that deserve credit for some of this information are Chris Katthage, Josh Boam, Jim Snodgrass, Ricky B, Bill Wotschak and many others.
If you would like to add anything or correct and information that is inacurate or outdated please feel free to PM me on the board or send me email. You can find me on www.mr2oc.com.
- MrTurrari
Brian R. is offline
Old 04-24-2006, 03:44 PM   #50
Brian R.
Resident Chemist
Brian R.'s Avatar
Re: Camry FAQs and Information - SEARCH/READ HERE BEFORE POSTING
GAS MILEAGE SAVERS TESTED
Thanks to Scholzee on the Blazer forum:
NEW YORK (CNN/Money) - Common gas-saving tips were put to the test recently by Edmunds.com, CNN.com's automotive content partner.
While most, it turned out, actually did save gas, some of the fuel-saving advice you commonly hear didn't make much difference at all.
Drivers took two different vehicles on the same 56-mile route eight times under various conditions. The vehicles, both Ford Motor Co. products, were a 2005 Ford Mustang GT and a Land Rover LR3 SE. Both have V-8 engines. The Mustang's EPA-estimated mileage is 15 in the city and 25 on the highway while the Land Rover's is 14 in the city and 18 on the highway. In ordinary driving, most vehicles usually get about 15 percent lower gas mileage than EPA estimates indicate.
Using cruise control
Drivers are often advised to use cruise control during long highway drives on level roads. The idea is that it prevents "speed creep" -- the tendency to gradually start going faster the longer you drive -- and cuts down on other unnecessary speed changes which can eat up gas.
In Edmunds.com's test, the Land Rover got almost 14 percent better mileage using cruise control set at 70 miles per hour rather than cruising at driver-controlled speeds between 65 and 75 miles per hour.
The Mustang got 4.5 percent better mileage with cruise control.
Verdict: It works
Roll up windows, use A/C
When driving on the highway, most of a vehicle's power is used simply to overcome aerodynamic drag. On the other hand, air conditioning also uses a lot of power.
Drivers are often told that keeping the windows rolled up, which significantly reduces drag, and using air conditioning actually results in better fuel economy than driving at high speeds with the windows open. In fact, CNN/Money has offered the same advice in a story we've run on our site.
In Edmunds.com's test, conducted at a steady 65 miles per hour, "windows down" or "A/C on" made virtually no difference in mileage.
The Mustang got 4.1 percent better mileage -- 30.7 mpg vs. 29.5 mpg -- with the windows down. The Land Rover got 1.6 percent better mileage with the windows down, a difference of just 0.3 miles per gallon.
Basically, the extra fuel used by the air conditioner is made up for in improved aerodynamics at high speeds. Your not really saving any fuel but, at least on the highway, the A/C isn't costing you appreciably either.
Verdict: No difference
Avoid hard acceleration
You've probably been told before that rushing up to stop lights and racing away from them wastes gas. Turns out it wastes a whole lot of gas, according to Edmunds.com's test.
Slowing zero-to-sixty times to 20 seconds instead of 10 to 15 seconds makes a big difference in mileage over the long term. Braking slowly and gently helps, too.
Driving the Land Rover gently resulted in a 35.4 percent increase in gas mileage while feather-footing the Mustang garnered a 27.1 percent mileage increase.
Verdict: Big difference
Properly inflate tires
Not having enough air in the tires can cause a number of problems, including a potentially dangerous blow-out. But it also reduces gas mileage.
In Edmunds.com's test, the mileage improvement with properly inflated tires, compared to slightly under-inflated ones, was slight but noticeable in the Land Rover but non-existent in the Mustang. Still, for safety's sake, keep enough air in your tires.
Verdict: Small impact on mileage
Brian R. is offline
Old 05-14-2006, 12:32 PM   #51
Brian R.
Resident Chemist
Brian R.'s Avatar
TRANSMISSION FLUSH PROCEDURE
Q: How can I flush my transmission fluid without bringing it to a shop?
A: Here is one way posted by popeye08:
(from http://townhall-talk.edmunds.com/dir.../.ee9950e/4658 )
You can actually change virtually all the fluid in the system using the following method. We have 5 Toyota's in the family, and I have done this to them all at least once.
It takes about an hour. Use whatever fluid is recommended on the dipstick, or in the manual. Our Camry's and Corolla's take Dexron, but the Celica takes Toyota Type IV fluid, available only from Toyota, at about $3.50/qt. Use what's recommended, or you'll be sorry. It's still less expensive than having it done.
1. Drop the pan*, drain the fluid, replace the filter, and reinstall the pan as you usually do.
2. Add 3 quarts of fluid. (or however many quarts of fluid are drained from the pan).
3. Remove the fluid return line at the transmission (usually the upper of the two lines), and place it into a one-gallon milk jug or similar semi-transparent container. You may want to place the container in a box with rags around it so that it doesn't spill.
4. Start the engine, and let about a quart or so of fluid get pumped into the milk jug (about 10-15 seconds).
5. Stop the engine, and add a quart of fluid to the transmission.
6. Repeat steps 4 and 5 until you get new fluid out of the drain line.
You'll use about 8-10 quarts of fluid total, including the 3 you put in at the beginning, so you may need more than one milk jug.
7. Reinstall the drain line to the transmission, start the engine, and check for leaks.
8. With your foot on the brake, put the transmission in each gear, then into Park.
9.Let the car down and check the fluid level on the dipstick. Add fluid if needed to bring it up to the proper level.
10. Take it out for a test drive, and check the fluid level again.
(*One caveat is that it is not nessary to drop the pan. Removing and replacing the filter is not necessary. It is more or less just a screen that doesn't get plugged unless your clutch plates shread or something equally traumatic happens. Brian R.)
Brian R. is offline
Old 05-28-2006, 02:11 PM   #52
Brian R.
Resident Chemist
Brian R.'s Avatar
Information About Auto Repair and Some Tricks About How Not to Get Ripped Off
Info thanks to Flatrater.
This is an article I found on the web. Now please read this as it impacts all of the car owners getting their cars worked on in a dealer or an outside shop. This is how it works use it to learn and to prevent getting ripped off by any shop.
"After working over 15 years in the auto repair industry, I have some insight I would like to share with everyone. The auto repair industry has changed quite a bit over the years as more complex automobiles have driven a new kind of mechanic into existence. Some of this has fostered smarter, better trained mechanics. However, it has developed the parts swapping business into enormous proportions. Part of the reason I changed careers was because I was so frustrated by working in such a crooked environment. Bad mechanics that lacked morals made the most money and honest ones lagged behind significantly. One key problem with the auto repair industry is the flat rate pay system which nearly all repair shops use. Basically it works like this: Labor time manuals are printed by the manufacturer for warranty repair time standards. These are times for a given job that are preset and are rounded to the nearest 1/10 of an hour. For instance, the replacement of an ignition module on a particular car may pay 1.1 hours in the warranty manual. That means that no matter how long it takes the mechanic to change that module, he still gets paid 1.1 hours. Aftermarket flat rate manuals are used for after warranty repairs. These manuals usually just take the warranty manual and multiply the time by 1.5. In some cases special times will be used instead. A mechanics flat rate time charge is usually referred to as a flag. For instance, the mechanic changing the module above will flag 1.1 hours for it under warranty or 1.7 hours retail.
Most mechanics are paid 100% commission based on what they flag. This is not always true but it is the overwhelming majority that are paid this way. For these mechanics, the motivation is to flag as many hours per day as possible. It is not impossible, or even that uncommon, for a mechanic to flag over 16 hours in an 8 hour day. The mechanic will make a given wage per flat rate hour. If he flags no time in a given day, he makes no money at all. Few shops guarantee a minimum income. There is no real maximum either. It is not unheard of for a fast, crooked mechanic to flag well over 80 hours in 5 day a week while working only a little over 8 hours per day. Thats not to say all mechanics that flag big hours are crooks though. The work load can be seasonal too. It was quite common to have a 50% or more pay fluctuation (flagged hours) from winter to summer.
The shop effectively makes a portion of what the mechanic flags so they too are interested in having the mechanic flag as many hours per day as possible. There is little motivation to be honest and quite a bit of motivation to rip off the customers. Most shops will not pay a mechanic to do a job twice. If a mechanic changed a water pump for instance, and the car came back with a leaking water pump gasket, the mechanic would have to replace the gasket and charge no time. The problem is that it is in the best interest of the shop and mechanic to blame the leak on something else that they can charge the customer for. Electrical and electronic parts typically have about a 30% to 60% no fault found rate on warranty returns. That means that about 30% to 40% were misdiagnosed in the field or the failure was not found during lab analysis.
Dealers/managers love those high speed guys because they make the company a ton of money. They figure what's a few blown out customers compared to a good profit. They're not going away, in fact, they are becoming all too common because that's what it's coming down too. Tech's haven't got a cost of living increase in years. When you ask a manager for a raise he says, "You want a raise, make more hours!" A few managers base their mechanics pay on hours produced. Techs working over 80 hours a week got a $2 per hour raise over a 40 hour tech. It is the exception to find a company giving a raise to the tech with the highest customer satisfaction.
There is not really a flat rate time for diagnosis in most cases. This means that a good mechanic that can troubleshoot a problem in 0.5 hours may charge significantly less than a clueless mechanic that spends 2 days swapping parts to figure it out. In the first case, an honest mechanic will flag 0.5 hours. Some may claim that since they are so smart, they will flag 0.8. In the second case, the same repair will cost the customer 2 full days plus any additional parts that were swapped as a guess. Again, there is very little incentive for the shop owner to intervene unless the customer complains.
Many mechanics will guess and swap parts until the problems are solved or the customer runs out of money. Only about one quarter of the mechanics out there can really troubleshoot problems accurately. Of those, only a portion can troubleshoot intermittent and more difficult problems. Most electrical and driveability problems on today's automobiles are intermittent. If you find a good mechanic you can trust, stick with him and tell all your friends.
On the other side of things, mechanics are often blamed for problems they did not cause. It seems all too often that a customer would claim the oil change we did caused their headlamps to flicker intermittently or some other bizarre problem that is in no way connected. Customers also seem to think that today's cars are smart and that there is some mystery machine hidden in the the shop that, when plugged into the car, will tell the mechanic everything that is wrong from low tire pressure to internal engine problems. This is far from accurate. Yes, modern cars do have sophisticated electronics on them and they do give the mechanic information such are fault codes and data values but they don't troubleshoot and they never will. On board software does have the capability of determining an out of range sensor or improper outputs. It can give the mechanic valuable information to help him narrow a problem down. It will never troubleshoot for him! An engine control for instance, which is generally the most sophisticated control on the vehicle, can only read values at the pins that connect it to the wiring harnesses. It can determine if a circuit is open or shorted or out of normal range but that is about it. It is up to the the well trained, smart mechanic to determine where the actual fault is. As I said earlier, most electrical and driveability problems are intermittent. That means that no matter what tests you run, chances are they will all pass. This is where data loggers and real smarts come into play.
It seems for the most part that bigger cities have more crooked shops than smaller ones. I think this is because a poor reputation in a small town will put you out of business whereas in a big city there are plenty of customers to go around. The strategy is usually to get all they can out of you when you do come if assuming you won't be back anyway. Also watch out for "mechanic of the month" award winners. These guys are usually the ones who flag the most hours to get a bonus on top of it. They are generally the most crooked as well.
Examples
I will now give a few real world examples of some of the things that go on in a shop. A new car dealer had a scam going that involved all the service personnel. They would bring new cars right in off the convoy truck and claim every one had alignment problems, driveability problems, and transmissions problems. Each of 3 mechanics would flag the maximum allowable time for work they supposedly did although no work was really performed on most of the vehicles. While these were all warranty claims, it is still fraud and the manufacturer was getting ripped off for more than a year. Some of these mechanics were being paid a 6 figure income by all the phony time they flagged. The dealership was finally caught and closed down but those same mechanics got jobs at other dealers. How would you like one of them working on your car?
A little old lady brought her car into a shop. A mechanic sold her over $2000 worth of parts and labor and the car was still not fixed. After all of that, it turned out there was a bad spark plug wire causing an intermittent misfire. The customer was still charged the full amount and none of the unnecessary parts were removed.
One mechanic was charging for piston ring replacements on certain vehicles under warranty on a routine basis. Few of the engines were ever taken apart. He would work at a dealer for a year or so until others would start to suspect and then go to another dealer to do it again. He rarely worked a full day but typically got paid over 12 hours per day.
During the 1980's, before detergent gasoline and deposit resistant injectors, the injectors would periodically need professional cleaning. The process typically pays about 1 hour but really only takes about 15 minutes of a mechanics time since he can connect the machine, start the process, and do other work while the injectors are being cleaned. Starting in the late 1980's, deposit resistant injectors were introduced and detergents were added to gasoline to prevent clogged injectors. Some mechanics will still try to sell you an injector clean as maintenance. There are cases where injectors may need to be cleaned to correct poor running but it is really not a maintenence item anymore. Another similar situation arises with the throttle body. Throttle bodies will sludge up, especially if you use natural (non-synthetic) oils. It was common in the 1980's to periodically clean the throttle body. In the early 1990's, new measures were taken to eliminate the need to clean the throttle body. In fact, some throttle bodies come pre-sludged with a special coating to allow proper idle speed. If you remove the coating, your idle may be too high. Some mechanics still sell throttle body cleaning as a maintenance item. It generally takes about 5 minutes and they will charge you an hour. In some cases it will actually cause an idle problem where one was not previously present.
Warning signs?
There are a few warning signs you can watch out for:
  • Does your mechanic claim you need more than one part to repair a given concern? If so it is questionable. While it is possible to have multiple failures contribute to a symptom, it is more likely a single part or condition is at fault. Occasionally you could have one component failure cause another component failure but that is also less likely. Always ask for a detailed explanation of what the root cause of the failure was. Beware of the parts swapper who wants to change every part that he thinks may be causing the problem. A typical example would be an EGR system. Many mechanics will claim that the EGR valve and sensor should both be changed if either is faulty. This is generally not true. There were cases in the 1980's when redesigned valves would not work without a redesigned sensor but generally either one or the other is the problem, not both. Sometimes the mechanic will recommend several parts but only 1 may be associated with your original concern. That is OK as long as he explains what all the parts are needed for. Often times he is trying to sell you maintenance work or has found worn parts that do need replacement. There should be a reason for every parts that is replaced.
  • Do they claim that you need "maintenance" work that does not show up in the factory maintenance guides? Like I mentioned above in the examples section, there are many maintenance procedures that are no longer needed but are still sold as required. The injector cleaning and throttle body cleaning are 2 examples. Most late model vehicles require very little maintenance compared to those of 10 years ago. Today's cars will never need a tune up. Most cars will need spark plugs replaced at 100k miles but no adjustments are ever needed. The timing and idle adjustments and other things that were part of a tune up are history. None of that is adjustable anymore. All you need is spark plugs, drive belts, brakes, oil, and filters for maintenance on most cars. Most wheel bearings are not serviceable anymore either. Always check your factory maintenance guides to see what is really required (that is if you can find a good one).
  • Are they trying to sell you brakes? In many cases poor driving habits will lead to premature brake wear. I have seen poor drivers destroy brake pads in less than 25k miles. However, upselling brakes is one of the most common scams some mechanics will try. Typically, you should be able to run your brakes down to about 15% remaining before you need to consider replacement. It is too common for some mechanics to try to sell brakes at 50%.
  • Are they spending too much troubleshooting time? This is really difficult to determine if you are getting a fair deal or not. I found that people would generally rather pay to swap out parts than to properly troubleshoot a problem. Generally, any hard failure, one that is always occurring and not intermittent, should take less than a couple hours to troubleshoot but even that is a rough estimate. Intermittent problems are the hard, and more common, ones. If the problem is only an inconvenience, such as a hesitation, lack of power, or intermittent problem with a non-essential electrical system, it is best to let it get bad enough that it can be easily duplicated before bringing it in to a mechanic. Things such as the yellow "check engine" or "service engine soon" light are best to wait until they are on constant as long as no other symptoms exist. It is not a bad idea to have a quick checkout of 1 hour or so to see if it is something simple but spending much more than that on a real intermittent problem can be futile. If it is a significant problem, like dying, then you had better get it fixed. This means determining the actual root cause of the problem, not just swapping parts until it seems better. In some cases if there is a significant problem that happens so rarely it can't be verified by the mechanic, educated guesses may be your best option. However, that decision should be made by you and your mechanic should have already checked TSB's and recalls to make sure it is not a known problem with a fix, and done a thorough inspection and basic testing to see if the root cause could be determined.
  • Are they selling you a tune-up? Vehicles built in the last 10 years or so do not need tune-ups. They do need spark plugs and filters but that is it. There are no adjustments or other maintenance required. You don't need to scan for codes either. Even on vehicles with adjustable timing, it no longer needs any adjustment unless you are having a problem. It will not vary a significant amount in the first 100k miles. If your vehicle is due for spark plugs, get them replaced. You need to change air and fuel filters too but that is about it. Again, consult your factory maintenance guides.
What Can You Do?
  • Whenever possible, use a specialist. Today's cars are too complex for one person to be expert on everything. Generally the categories are: driveability, electrical (although driveability and electrical are about the same thing today), transmission, alignment, heavy line, light line, and maintenance. A good mechanic may have a couple categories he is strong in. It is important that a mechanic is well rounded and have knowledge of the complete vehicle. He could probably perform tasks other than his specialty but his specialty area should be by far his strong point and it should also be what he concentrates on. Compare it to a doctor. You do not want a skin cancer specialist doing heart bypasses. The same is true in the automotive field. Dealerships have the best tools and training and usually have enough mechanics to have specialists. Many times however, independent shops will be more honest.
  • Avoid the "mechanic of the month" award winners. These guys usually get there by flagging the most hours. That is a warning sign that he likely has the least morals and will try to get all he can out of you. That is not always the case but it is a warning sign to me. This can be a tough call. There are times when this guy is just fast and good.
  • Explain your problem in as much detail as possible. Don't just say "it runs bad". Explain exactly when it does it, how often it does it, when it started, how you are driving it when it happens, etc. Don't try to diagnose it! I used to have customers say things like "I think it's the carburetor" all the time. That does no good. I got the worst problem descriptions from men who wanted to appear knowledgeable rather than just describe the problem in plain language. Women were usually better about just describing the symptoms. If the problem is intermittent to any degree, say so. The absolute best thing to do is to take the mechanic for a ride in the car and show him exactly your concern. Make sure you are driving so you can show him exactly what your problem is, then let him try to duplicate it.
  • Use word-of-mouth to find an honest mechanic. Beware however that some people don't know a rip-off even after it has happened repeatedly to them. If they recommend someone, ask for details. Was more than one part required for the repair? If so, why? What other work was sold to them at the same time? Once you find an honest mechanic, stick with him. Get his name and request him every time. Tell all your friends. There are still many good, smart, honest mechanics out there and they deserve all the good business they can handle. This too may be difficult to determine word of mouth since some people think they are getting ripped off when they are not at all.
  • If you get ripped off, tell everyone you know, fight it with the shop owner, and make as much of a stink about it as you can. Don't let them get away with it. Report it to the Better Business Bureau. It is time to send a strong message to crooked mechanics and shops. Shut them down.
Lacking knowledge of modern automobiles can really open you up to rip off artists. ASE certification does not mean you have competent techs, although it is a step in the right direction. I passed the heavy duty truck brake tests and I had no idea how the systems even worked and had never worked on one. I also passed the transmission tests with little knowledge or experience on transmissions. The tests are generally too easy and they give no indication of how honest the mechanic is. While ASE may attempt to better the repair industry, and they do help, they can't fix the root cause of the problems. I would, however, recommend ASE certified mechanics over those that are not. I want to make it clear however that there are some very sharp and honest mechanics out there who are underpaid for their ability. Sadly, it is the parts swappers and mechanics that do maintenance that really bring home the most money despite lower pay per flat rate hour in many cases than specialists. Training usually pays actual time at best. Some dealers don't even pay for training. The affect is that mechanics have less motivation to attend classes.
Most vehicle manufacturers now require at least some degree of training which is helping to drive the right behavior. Modern mechanics working on high-tech systems require a significantly higher skill set than mechanics of yesterday. Vehicles have become very complex. Most of the problems on these high-tech systems are intermittent making it even harder. Some manufacturers don't seem to understand what it takes to troubleshoot problems on these modern systems and believe that the mechanics out there simply don't have the aptitude to learn what they need to so they don't give the detail of information required to really understand these systems. This adds to the challenges a good mechanic faces. Modern vehicle troubleshooting requires many of the techniques a doctor would use to troubleshoot problems with humans. The real frustration comes when these vehicle doctors take home less money than a mechanic that just swaps parts. I would guess that only about 10% of the mechanics out there fit into the vehicle doctor category. Another 20% have some skills for troubleshooting. Many of the rest just swap parts and their skill is the speed at which they can change these parts. Often it is the doctors who really end up troubleshooting most of the problems for the others but he does not make the money for it. That should be improving as vehicles become more complex.
Modern vehicles are significantly more reliable than older ones. The newer the better. Modern vehicles require very little maintenance and very few repairs compared to those just 10 years earlier. Generally, any of the larger automakers make a better quality product today than the best cars of 10 years ago.
I blame most of the problems with the repair industry on the flat rate pay system. It can drive the wrong behavior throughout the organization. It gives clear incentive to go for speed and not accuracy. How would you like your pay cut in half because business was slow. Go home and tell your family that and see how it makes you feel. Upsell becomes easier to justify. It can be a very stressful living. Now work in those conditions and watch the guy next to you cheat the system and rake in the money with bonuses and praise from management to boot. Mechanics are no more dishonest than anyone else by nature, flat rate pay is to blame. "
Brian R. is offline
Old 07-05-2006, 09:11 PM   #53
Brian R.
Resident Chemist
Brian R.'s Avatar
ENGINE VACUUM HOSE ROUTING DIAGRAM
Q: I'm having trouble isolating a vacuum problem. I've checked the egr - good, replaced ALL vacuum lines, but car still misses at 20-25mph and 45-50mph. with egr vacuum line d/c'd the miss is gone. while trying to make sense of manual, i came across pic of egr and vacuum lines as they are connected in the pic - they don't match my cars egr vacuum lines although the pic is supposed to represent same. if anyone can direct me to an appropriate manual, or even better, if someone can send me a diagram it would be much apprieciated.
A: Give your VIN to a Toyota parts department and they should be able to order a vacuum routing diagram for you to stick under your car hood (if there isn't one already there). This is the best diagram to follow for your car. They have to have these available for cars who have to have their hoods replaced.
Brian R. is offline
Old 07-08-2006, 08:40 PM   #54
Brian R.
Resident Chemist
Brian R.'s Avatar
Brian R. is offline
Old 07-19-2006, 08:05 PM   #55
Brian R.
Resident Chemist
Brian R.'s Avatar
DIFFERENTIAL MAINTENANCE
Q: My car model is 1998 Camry XLE. One month back I flushed the Transmission fluid and replace it with new fluid. Do I also need to change the differential fluid?
A: No, you don't. By 1998 they had integrated the differental supply with the A/T supply. Although the diff still has it's own drain plug, it is filled with the transmission supply. Differentials before 1998 have to be separately filled like a gearbox, only with ATF.
Just keep adding to the transmission supply until it reads normal.
That means bring the car up to temp by drving around the block. parking. Shifting through all gears & THEN checking the transmission fluid level with the engine idling.
Brian R. is offline
Old 07-29-2006, 06:47 PM   #56
Brian R.
Resident Chemist
Brian R.'s Avatar
TESTING MAP SENSOR FUNCTION FOR DTCs P0105 AND/OR P0401
Q: I’m troubleshooting a Camry 2.2L for Codes P0105 and P0401 and would like to know if anyone can confirm the following figures are correct for the MAP sensor.
According to Haynes 97-01 Toyota Camry Manual (page 6-11)
(3) Using a voltmeter and suitable probes, back probe connector terminal 2 with the positive probe and terminal number 1 with the negative probe – Turn ignition switch on (engine not running).
(4) Apply vacuum to the sensor and verify voltage from the signal wire-
.03 to .05 volts @ 3.9 in-Hg
.07 to .09 volts @ 7.8 in-Hg
1.1 to 1.3 volts @ 11.8 in-Hg
1.5 to 1.7 volts @ 15.75 in-Hg
1.9 to 2.1 volts @ 3.9 in-Hg
This is what I have at this point:
ECM side (disconnected)
T(3) to T(1) is 4.5 volts
T(2) to T(1) or ground is 3 volts
Back probe T(2) and T(1) vacuum results (connected with Ignition Switch "ON")
MAP # 1 (Original MAP sensor)
3 volts @ 0 in-Hg
3.25 volts @ 4 in-Hg
2.5 volts @ 7.8 in-Hg
1.85 volts @ 15.75 in-Hg
1.45 volts @ 19.75 in-Hg
This MAP sensor shows codes P0105 and P0401
EGR system checks out ok
MAP # 2 (reference MAP sensor)
3.00 @ 0 in-Hg
2.75 @ 4 in-Hg
2.00 @ 7.8 in-Hg
1.75 @ 15.75 in-Hg
1.5 @ 19.75 in-Hg
Neither of these readings correspond with those in the Haynes manual. What am I doing wrong?
A: The description of the expected voltages in the Haynes manual is incorrect. The voltages listed are not the expected voltages as Haynes states they are, they are the voltage drops expected from the reference voltage. Haynes does not even tell you to measure the reference voltage correctly. They call the ECM supply voltage to the MAP sensor (Terminals 3 and 1) the reference voltage which is incorrect. The reference voltage is the voltage between Terminals 2 and 1 with the vacuum line disconnected and the connector attached and the ignition key "ON" (see below).
With the connector attached and the ignition on and the vacuum line disconnected, measure the reference voltage by backprobing terminals 2 and 1. Measure the voltages at these same connectors while applying different vacuums at the port. If your reference voltage without vacuum is 3 volts (for example), then you should see the following voltages at these vacuums:
3.94 in Hg 2.5-2.7 V [3.0 V (reference voltage) minus 0.5-0.3 V]
7.87 in Hg 2.1-2.3 V (3.0 minus 0.9-0.7 V)
11.81 in Hg 1.7-1.9 V (3.0 minus 1.3-1.1 V)
15.75 in Hg 1.3-1.5 V (3.0 minus 1.7-1.5 V)
19.69 in Hg 0.9-1.1 V (3.0 minus 2.1-1.9 V)
Apparently this is what you have done, without knowing that you needed to subtract the given voltages from the correct reference voltage.
Since your MAP #1 shows 3.25 V at 4 in Hg, It appears it is bad. That is higher voltage than the reference voltage (3.0 V) when it should be lower. Recheck your measurement, but it appears your DTC with this MAP confirms it is bad. Replace the MAP if this is a real measurement.
Although the second MAP is not exactly what is listed above, the trend is the same and I would assume it is good. Perhaps you didn't measure the reference voltage exactly correctly. This would bias all the measurements equally and in one direction. I don't think there is anything magical about these absolute numbers as long as they are close to the above ranges, it is having a smooth trend that is important. There is bound to be some variation with altitude.
The following link is to the procedure from the Toyota maintenance manual [notice that it says "(e) Measure the voltage drop from step (c) above for each segment", where step (c) measures the MAP output voltage with the MAP sensor (2 vs 1) disconnected from the vacuum line]:
http://i16.photobucket.com/albums/b8...5S-FEMAP-1.jpg
Brian R. is offline
Old 08-09-2006, 12:30 AM   #57
Brian R.
Resident Chemist
Brian R.'s Avatar
HOW TO ADMINISTER SEAFOAM TO CLEAN YOUR ENGINE
(Thanks to Toysrme for the following discussion)
Seafoam makes the world go round!
Not really, but at $5 a can it's a steal.
A can is 1 pint.
You need 2 cans.
Pour 1/2 a can in the gas tank when you stop to fill up. (This ensures it mixes well)
Pour the other 1/2 in with fresh engine oil.
At the least you will notice that the engine will idle noticeably smoother.
Here's where most people get confused. Using it down the intake to clean the combustion chamber & parts of the head.
1) Drive the car around the block until it comes up to temp
2) Pour 1/3 of a can into a separate container (1/4 of a can for 4 cylinders)
3) Crank the engine
4) Pull the brake booster hose off & put your finger over the end so the car doesn't lean out & stall.
5) Drop the hose in the bottom of the container & let your finger off the end. If the engine doesn't stall out completely SHUT IT OFF ASAP.
The fluid will near instantly disappear & the engine should stall from being too rich to run, or being too lean from the hose letting air in afterwards. This will not break your engine. You're not using enough fluid to hydrolock it.
6) The engine should sit for 5 min.
7) Crank the engine & let it run until the smoke dies down
Normally you will get an ungodly amount of smoke.
8) As the smoke dies down, drive the car around. Be sure to make liberal use of 1st & 2nd gear to get to the higher portions of the RPM range a few times. That would be 5000-6850rpm..
You are not breaking your engine by running it at those rpm... All of the computers on all of the engines will cut the fuel to slow the RPM down before the engine is damaged. Yes, they are built for it...
Why someone would want to do this?
To clean gunk, sludge, & misc. heavy buildup out of the oil system. Pump, passages, bearings, walls.
To clean the fuel system.
To clean carbon out of the combustion chamber.
Now some people ask why you want to go to the trouble of cleaning carbon out of the engine.
Because as it builds up on the valves, they don't seal as well - causing poor compression while the leaking gas superheats parts of the engine that are not designed for it.
Because carbon in the combustion chamber is bad. mmmm kay? Any carbon becomes superheated. Superheated carbon / metal will cause the incoming fuel & air to ignite earlier than it should be. This (Detonation, pinging, kocking - all just names for pre-ignition) is very derailment to many aspects of engine life.
This is what a 3vz-fe looks like @ 95,000 miles.
(Forget the fluids, fluids spill look at the black carbon build-up)
Here's what it looks like 6 months after the last 3 Seafoam treatments.
Seafoam = Good. It's cheap & versatile, while working at least as good as anything else; regardless of the cost.
Brian R. note: GM Top Engine Cleaner is another useful additive for the above purpose.
Brian R. is offline
Old 08-11-2006, 06:50 PM   #58
Brian R.
Resident Chemist
Brian R.'s Avatar
Toyota Approves Use of 0W-20 and 5W-20 GF-4 Oils
Toyota has approved the use of 5W20 GF-4 oils (e.g., Mobil1) in most modern engines, and 0W-20 in 2AZ-FE engines as shown in the folowing TSB.
I have been using the 5W-20 oil in my 5VZ-FE 4Runner engine for about 6 months now and can see the difference in mileage.
It doesn't appear that either of these oils are approved for the 22R, 3S-FE or 5S-FE engine. I have been using a 50:50 mix of the 5W-20 and 5W-30 Mobil1 in my '96 5S-FE Camry for about 8k miles without any noticable problems.
Brian R. is offline
Old 08-12-2006, 05:00 PM   #59
Brian R.
Resident Chemist
Brian R.'s Avatar
BUYING A CAR/TRUCK - WHAT TO LOOK FOR
Q: I'm about to purchase a mint vehicle, is there anything I should know about it before I purchase it. it only has 60k original miles. and great body.
A: Timing belt may be due to be changed at 60K (or 90K), an added expense.
Check the CV boots and see if they are torn - or grease has been thrown over the underbody in the area of the CV joints. Expensive repair.
Check the color of the ATF. If it's really dirty, it may have never been changed and you may have a potential problem there. If it's mud, don't buy it. If it's just reddish brown, get it flushed as soon as you can. Make sure it shifts smoothly, quietly, and without a jerk. May indicate a problem.
You should actually flush (not just drain & refill) all fluids ASAP after buying the car. Oil change, Transmission, Coolant, Brake lines, Powersteering fluid. Keep this expense in mind.
Pull the oil filler cap and see if there is bright shiny metal visible or are there extensive black deposits, indicating a lack of maintenance. If there is alot of black crap visible, don't buy it. Check for oil leaks under the engine and transmission.
Have the brakes checked and see if they need to be changed. That will be an added expense after you buy it. Tires are costly also.
Make sure there is no smoke or steam coming out of the exhaust, either when just starting it or after it is hot. May be a sign of having been overheated or other serious problem. Don't buy it.
Check the coolant to make sure it is pretty red or green. No foam, bubbles in the overflow tank when the engine is running, or discoloration. If there are foam or bubbles - don't buy it.
Engine should run smoothly and quietly, no jerking, hesitating, or "Check Engine" light showing. Check recent emissions results if available.
Car should have no vibration at any speed. If there is any vibration, see if there is a bump in one of the tires. Anything else - don't buy it. If one of the tires has a bump, get it replaced as soon as possible. Take the cost of 4 tires into account if they are pretty used. You don't want one new tire on a set of badly used ones. On the test drive the vehicle should steer straight with no excessive side pull and the steering wheel should not be off center when driving on a straight road. Make allowances for an alignment and maybe front-end work if you find these indicators. Could be expensive.
Bounce the car hard, front and back separately. If it doesn't stop bouncing immediately, you may need to buy a set of struts. This can be expensive. As a general rule, there should be nothing wrong with the struts at 60K. If the car is a relatively new model, it may indicate that the car has been abused (or the speedometer has been rolled back). If the car is really old, the struts may be shot due to age alone. Mileage is not the only indicator of the expected strut condition. An old car doesn't have to have been abused to have bad struts at low mileage.
Along these lines: regardless of whether or not it has been driven hard, or sitting still, any car, regardless of make, can be expected to get around 10 years on the factory struts, springs, and rubber type mounts (i.e. strut mounts, bushings, engine mounts, etc.). And that it is fairly downhill quickly from there.
Check under the car for shiny welds or a lot of new parts that may indicate the car has been extensively fixed because of a collision. Also check the dashboard and see if it has a VIN in front of the driver, no VIN number indicates it has been replaced - check the VIN against the title. Don't buy it if anything is wrong.
Check the body panel fasteners. Example - Fender, Hood, Door, Trunk bolts, etc. Signs of chipped paint, disturbed mating surfaces, and tool usage may indicate that the vehicle has had body damage and been repaired. Run your fingers along the seams between the body panels. Wavyness or uneven spacing in the body panels indicates the presence of collision damage. Likewise, check the shock towers for welds, indicating repairs.
Check all the lights, turn signals, cruise control (may be designed to work only above a certain speed), and other electrical components for proper operation. Also check that the air conditioning blows cold air and the heater works.
If you don't know the car's history, check CARFAX.com for history. Only buy it if it has a squeeky clean history.
There are other cars available that don't have potential serious problems. Don't take chances if there are unknown costs after the purchase. Don't buy it if there is any doubt about it's condition. Have a mechanic look at it - it is worth the money.
Brian R. is offline
Old 08-13-2006, 12:31 AM   #60
Brian R.
Resident Chemist
Brian R.'s Avatar
FIXING CLOGGED SUNROOF DRAINS
Q: I have a 2001 Camry. The drain on the sunroof keeps clogging up and I have to take it in to the dealership to be cleaned out. Can anyone tell me how it is done so I can avoid the expense of taking my car in a couple of times a year to get this done???....help.....thanks if you can explain!!!....
A: The sunroof has 4 drain points. 2 in the rear and two on either side in the front. 1/2" plastic tubes go from either point in the front through the side pillars and drain out the front fenders. The pipes can also be seen in the front if you remove the kick panel on the side under the glovebox. The tube should be behind the electrical panel which also has to be removed. Pipe should be seen going into the ftont fender. Make sure its not kinked. In the rear they drain out in the trunk area near the wheel wells, near where the jack is stored.
Pour water into the sunroof channel. If the water drains out at all 4 points all is well. If it doesn't drain out of the front tube, the tube could be kinked or blocked. For the front take out the sun visor and pry the headliner to see the connection with a flash light. Twist of the clamp and blow compressed air through it making sure you do not damage the headliner. For the rear you can open the trunk and blow air out through the pipes to clear any blockage.
Pretty simple.
To prevent it from happening make sure you close your sunroof whenever you exit the car to avoid debris from collecting in the channels.
Thanks to burki limousine for the above explanation
From Toysrme:
We have the same problem on ES 300's from time to time. The rear 2 drain holes are inaccessable without taking the sunroof out. Once they're clogged. That's it for most home-mechs.
Blow compressed air in the front 2 drain holes (in the sunroof). 20psi, then afew seconds of 40psi.
Don't go crazy with the pressure, or time you spray in it. You can knock the drains around & that would be bad... Generally a sub 1-second blast will clear a blocked drain. If it's been leaking, expect a rush of water under the car.
The drain holes are located one at each corner in the sunroof. If hard to see, just run your finger in the ridge until you feel it.
Brian R. is offline
Closed Thread
