Go Back   Automotive Forums .com Car Chat > Toyota > Celica
Old 02-26-2006, 09:52 AM   #46
bo nada
Re: Read if ur wondering about the 3sgte swap
91 celica st ( thanks alot..... the gear prop. solve ) but:
i swaped the engine(3sgte) with the 3sge gear but when i start it its working for 5 to 8 seconds only..
i changed the turbo press. sensor its same...
my Q? is : is there any effect for the third plug in the ecu i mean the one going to the dashboard coz we not change dash. wiring we use the orginal ( 3sge )
or there is some thing else...
plz help me out i want to drive this motor...
thanks for all..
bo nada is offline   Reply With Quote
Old 02-26-2006, 04:49 PM   #47
91 Celica St
AF - Advisor
wait u used the original wiering harness for the 3sge and 3sgte ecu?
if so the sensor your talking about is tvis(i belive) and thats why your car is not properly running, all the butterflys are either closed and starving it or open and flooding it w air....im betting the ladde
you need the 3sgte wiering harness, with a 3ste ecu, nothing less, a 3sge ecu will work on a 3sgte w a tvis elimination plate but you wont have a knock sensor and you dcould dt like a bitch
FYI im looking for a 6th gen gt to swap a 3sgte into in the next few months...
91 Celica St is offline   Reply With Quote
Old 03-10-2006, 09:57 AM   #48
bo nada
thanks alot .....
i know i am trublling u ...
finally the car runs but .. do u have any idea about changing or rewire the orginal ( 5sfe ) fuel pump.. because , when the rpm reach 4000 and boost meter on 1 psi , the engine had fuel cut ..
still i dont know the power of the engine because of that cut
Old 03-15-2006, 12:10 AM   #49
91 Celica St
AF - Advisor
is it cutting completely, or does it seem like its running out of fuel(starving)
ALOT of people with this swap have a problem of not being able to revv past 4000 rpm, most are fixed by replacing the wiereing harness (but imn sure iu dont want to do that ....was the wiering harness cut when you bought it or was it complete? look on the other forums of how they corrected it, i belive most have a bad harness, ill double check...hopefully thatas not the case
Old 03-16-2006, 10:41 PM   #50
yotas4life
wait are you using the stock 5sfe fuel pump? that can only handle about 8 psi of boost, you need to change that, go on ebay and get a walbro 255lp supra pump, or find one over 150 lp
btw that thrid plug is a dash plug, if its not plugged in you wont have any readouts
yotas4life is offline   Reply With Quote
Old 08-22-2006, 02:12 AM   #51
BMar
Would a 2SGTE ST205 motor fit in a 2000 celica?
BMar is offline   Reply With Quote
Old 08-23-2006, 04:46 PM   #52
blakscorpion21
blakscorpion21's Avatar
you mean 3sgte? if so yes, but its not worth it. alot of changes are needed.
blakscorpion21 is offline   Reply With Quote
Old 08-24-2006, 08:04 AM   #53
BMar
Well, i want to do a engine swap into my 2000 Celica GT-S. I have heard these motors dont go well with a turbo. Do you have any suggestions?
Old 08-24-2006, 10:35 AM   #54
blakscorpion21
the 2zz is the best engine you can get with the 7th gen. as long as you run low boost youll be able to turbo it. even getting your block fully built prolly wont cost as much as a 3sgte swap and will be stronger than a stock 3sgte.
Old 10-10-2006, 10:49 PM   #55
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Here's a couple of really nice 3S-GTE links:
http://www.mrcontrols.com/primers/power.htm
http://www.mr2-tech.com/bgb/mechanic...mechanical.htm
Thanks to the MR2 forum...
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 10-20-2006, 08:14 AM   #56
kevbo2005
My 90 gts is getting an engine swap with the gt4 this week. Has anyone heard of a 'standalone' to replace the wiring harness of the engine. Supposively Im getting that, not sure, but it is suppose to minimize wires in bay area plus it has a boost control built into it. It cost about $1500. What do you guys know about it?
kevbo2005 is offline   Reply With Quote
Old 11-29-2006, 08:56 PM   #57
91 Celica St
AF - Advisor
a standalone is an engine managment system like apexi power fc and such, it replaces your stock ecu
IMO you shouldnt have odne that. should have swapped it with the harnesses and stock ecu then replaceed the ecu after it got running
your most liekly going to run into some headachs because of this
Old 01-13-2007, 10:49 AM   #58
NotoriousScrat
I just recently blew the head gasket on my '86 Celica GT (2SE stock engine) and I'm thinking that instead of fixing it I would rather swap in a 3S-GTE. The car has about 155,000 miles on it and my mechanic told me that head gasket is a weak point in this particular car's engine. Before I make any actual decisions, however, I have some questions about this particular swap. First, what should be done with the transmission if I get the swap? Would the original transmission (assuming a new clutch, etc) be able to be used and if that so would it be able to handle the new engine? Would a RHD wiring harness be usuable? Are there any things about this particular engine swap that would cause problems, and what are those problems?
I really appreciate any help I can get with this. Be warned however, that my knowledge of cars is somewhat basic (that's why I'll be getting this done instead of doing it myself for instance), so forgive me if I have to ask for clarification.
Thanks so much!
NotoriousScrat is offline   Reply With Quote
Old 01-22-2007, 12:30 AM   #59
91 Celica St
AF - Advisor
Thanks so much!
your mechanic is a tard. theres nothing wrong with the factory 2se headgasket
you should either get ahold of a 5sfe or mr2 3sgte transmission and use it. the mr2 (93+) is better than the 5sfe to use. if you used a 5sfe tranny you would need 5sfe disk 3sgte plate. te original tranny wouldnt b used.
yes you can use a RHD wiring harness. for$300 you can have your wiring harness done for you completely plug and play. PM me for details
depending on witch engine you get (and i would say get a clip) it can be pretty painstaking to not that bad
Old 01-23-2007, 12:49 AM   #60
NotoriousScrat
Forgive my ignorance but what's a clip? Thanks again.
