Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-05-2006, 06:33 PM   #16
SLoe
SLoe's Avatar
Re: The overheated thread
Originally Posted by TeamRedLine23
every time I turn the A/C off/on it makes a running water sound. should I be worried?
Do you overheat? Check the drain for the A/C. Probably stopped up.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
SLoe is offline   Reply With Quote
Old 12-05-2006, 06:37 PM   #17
TeamRedLine23
TeamRedLine23's Avatar
Send a message via AIM to TeamRedLine23
no I dont overheat, I just thought it would lead up to something such as overheating. as for the drain for the A/C, where is that?
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
TeamRedLine23 is offline   Reply With Quote
Old 12-05-2006, 09:35 PM   #18
Talon69
Talon69's Avatar
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Does it sound like ssshhhhhhhhh or something like that lol? And after the first big one by turning it on and off it gets less and less? If so that is normal.
Sounds like bleeding off sord of. Not water its your AC if this theory is correct of course
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD 13.732@98.396mph (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Talon69 is offline   Reply With Quote
Old 12-05-2006, 10:11 PM   #19
TeamRedLine23
yeah it does make a sssshhhhh sound. but the sound Im talking about actully sounds like running water but only for a second then goes away.
1997 Eclipse GS-T
Old 12-07-2006, 07:42 PM   #20
SLoe
SLoe's Avatar
Next time search :P Merry freaking christmas .... http://www.automotiveforums.com/vbul...ighlight=drain
Old 02-20-2007, 01:30 PM   #21
sprocketjuice
Exclamation Re: The overheated thread
I just wanted to add that when my DSM was overheating without the fans turning on, i checked the connectors and contacts of the cooling system for dirt/corrosion and cleaned them (i sanded them, with a file, dremel finishing brush and 1000grit paper). This alleviated my overheating problem.
sprocketjuice is offline   Reply With Quote
Old 09-06-2007, 11:14 AM   #22
BlackAcidProphet
Hey, new here. I have a '98 Eclipse GTS and it's been leaking water/coolant from the exhaust manifold. It's not the head and it's not the water pump.
BlackAcidProphet is offline   Reply With Quote
Old 09-06-2007, 11:26 AM   #23
david-b
Dave is THAT guy
david-b's Avatar
If it's leaking from the manifold it has to be the head gasket or a warped head. Either that or you don't have something hooked up right or something else is leaking.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
david-b is offline   Reply With Quote
Old 09-06-2007, 11:31 AM   #24
BlackAcidProphet
It's leaking from the two bolts that connect the exhaust under the manifold. It's not the head because the runs fine other than the water leaking out. There's no water in the oil and no oily water on the spark plugs.
I can't seem to find anything on this in the haynes manual either.
Old 09-06-2007, 01:21 PM   #25
SilvrEclipse
Holset powered 420a
SilvrEclipse's Avatar
Send a message via AIM to SilvrEclipse
Wow this thread is old.. Please dont bring up threads that are this old. You should have just made a new one with your problem in it.
Anyways, I wasn't awhere that there was an eclipse gts..
Your turbo has water lines that go to it, check those to make sure they aren't leaking. One of the lines could have a small crack in it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
SilvrEclipse is offline   Reply With Quote
Old 09-06-2007, 01:34 PM   #26
BlackAcidProphet
It was stickied so I figured I'd use it.
Yep they make them, and this car hauls major ass...
Thanx for the tip.
Old 09-06-2007, 02:22 PM   #27
SilvrEclipse
Holset powered 420a
haha Dude I was being sacastic. They dont make a gts, you had the letters backwards. GST
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-09-2007, 10:18 AM   #28
SLoe
SLoe's Avatar
Stop dirtying up my thread bitches Make a new thread in the right place. It's okay to bring up old threads if you have something useful to contribute.
Old 09-10-2007, 03:03 PM   #29
NateS
NateS's Avatar
Send a message via AIM to NateS
I have some usefull information to contribute to this thread.
Awhile back my car would keep pushing coolant out the overflow bottle under boost. The car would run fine babying it but as soon as I got into it would completly empty the coolant system and replace it with air. I thought it might have been the headgasket so I replaced it and did everything else I could think of. It turnt out to be a bad water pump/water pump seal. So if you come across this same problem this could be the answer for you.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
NateS is offline   Reply With Quote
Old 09-10-2007, 06:00 PM   #30
MazdaX
MazdaX's Avatar
Lets not forget the old air lock problem as well.
basically - system runs out of coolant , refill , somehow still over heats but no water vanishing and running through the coolant channels/hoses like a sloshy river - large air pocket somewhere stuck in coolant system = over heat , well not exactly always overheat but will run hotter and sometimes over heat but more a common problem with v-6's , v-8's , etc not so much the 4.
2004 Mazda 6i
1997 Tahoe
MazdaX is offline   Reply With Quote
