| Latest | 0 Rplys |
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
06-05-2003, 11:36 AM | #16 | ||
Re: golden eagle sleeves
Here's my view on this. They make a excellent sleeve. They do great work. My motor is a b18c1 and they sleeved it. I run 1bar daily on 93 octane and have run 25psi on C16, only being limited by my boost controller, otherwise i would run more. I would go with the arias 9:1 compression pistons and the crower rods. The limit on boost depends on what size turbo you the drag kit comes with because eventually you'll hit max boost and just be spinning hot air. Also, tunning, what are your plans for fuel managment. That will also help to know where you will stand.
00 civic with bolt-ons, i swear |
06-08-2003, 02:44 PM | #17 | |
I would like to know if I got JE 8.5:1 pistons standard bore, Eagle rods, Cometic head gasket, w/ ARP studs how much boost can I run off a drag 3 kit with 440cc injectors and an APEX I vafc?
06-08-2003, 03:29 PM | #18 | |
Get 550 cc injectors and run 20 PSI. But you have to get your block sleeved after 14 PSI. If you don't want to have the block sleeved then run the 440's and 14 PSI. But then you can get 9:1 compression with only 12-14 PSI.
06-09-2003, 09:00 AM | #19 | |
With only 440's and a afc, you'll still want to get a fmu and a intank fuel pump. I'm not sure if the drag kit comes with that. But even then on the 440's you could run up to 1bar on pump gas safely and close to 18-20psi on race gas.
PWMAN- You don't need to sleeve the block for 14psi. We have a stock gsr motor running 15psi on pump gas making 348whp.
06-09-2003, 02:18 PM | #20 | |
questions
I have alot of questions. First this is a list of the mods I have as of now that will be used with the turbo.
JG edelbrock intake manifold JG edelbrock throttle body aem cam gears unorthodox underdrive pulleys aem fuel rail and FPR MSD digital sci ignition and dist cap w/coil nology wires greddy evo exhaust dc short throw shifter These are the mods I plan on getting next ApexI VAFC RC 440cc injectors Drag 3 kit w/tial wategate comes with FMU and fuel pump JE pistons. Eagle rods Cometic head gasket w/ARP studs I plan on having this car as a daily driver and have decided that block resleeving is not needed for what I want. I am only interested in running 15 psi with this set up but I would like to run more with race fuel if you think it is safe with these mods. I would also like to know if eagle rods will hold up as good as crower. Also what compression piston should I be running for what I want? |
06-09-2003, 02:43 PM | #21 | |
what motor are you gonna run this on?
EDIT: lol I feel like a dumbass. Ok, you should beable to run at least 1bar daily on pump gas 93 octane. Running a little lean around 13:1 a/f isn't so bad on 93 octane. As far as will eagle rods hold as good as crower. Yes and no. I haven't had a problem making 450+ to the wheels. But if your shooting for 500+whp i would recommend shelling out the cash for the crower rods. I like the arias 9:1 compression pistons, it's what i use. And if you get low comp. pistons, use a stock honda headgasket. Also, with the 440cc injectors make sure you use a 12:1 disk for the FMU. Trust me, people will say you'll run way to rich, but in all honestly, some of the fastest street cars on the east coast run that setup before going really big. Hell i ran my 11.4 run using that setup. I would also run either NGK or MSD plug wires vs. nology.
06-09-2003, 05:48 PM | #22 | ||
06-09-2003, 08:42 PM | #23 | |
will a block guard, forged pistons, and eagle rods be a good investment if I'm planning on running 10 psi with a drag kit on a 95 integra? Or should I just forget it and run stock? I like to be safe and I don't want to wreck my engine. I heard good and bad things about block guards...some say it blocks coolant...some say it protects the upper part of the cylinders which are the weakest part.....Or should I get it sleeved and run 12psi??? Just want to be safe...better safe than sorry. I got a quote from a shop that would install a block guard, pistons, rods and of course a new head gasket and studs for $2400. Is that high? They said just to do the sleeves it would be $1200 not including rods and pistons. My integra has high mileage like 152,000 so I figure rebuiling it would make it kind of new.....would that be safe to turbo the car? it has no compression problems..just worried about the mileage...which is one of the reasons I would rather sleeve because I'd have new cylinders instead of 152,000 mile cylinders.....or would that be a waste of money???
JB |
06-09-2003, 08:49 PM | #24 | ||
06-10-2003, 12:02 AM | #25 | |
More Questions
For civic GSR.Why should I run the stock honda head gasket vs. a metal cometic head gasket? Also have you had bad experiences with nology wires? Also with my set up you read if I got everything how much whp should I have estimate? Have you had better experiences with Arias pistons than JE? Do you run a block guard on your motor too?
06-10-2003, 12:10 AM | #26 | |
Nology wires are a gimmick. Nothing will be gained by using them. Stock block, 15psi and Hondata Ive seen 276whp on an LS. (b18b).
Arias are higher quality and lower tolerances then JE. They are just better. Hence the price difference. A block guard will partially seal your deck... If your looking to go high hp, get sleeved from GEM (golden eagle.) Don't worry about the block guard. Yes. 2400 is INSANE for that work. Expect to pay around 1100.
Nothing left but a force fed hamster... |
06-10-2003, 08:05 AM | #27 | ||
Re: More Questions
Arias, JE they are both good, I just went with what i thought was the best. No block guard, if you sleeve the motor don't use it. I've heard of people overheating because it blocks some passage for your coolant, but then i've heard of others not having problems. Just sleeve the block, you'll be much happier. Well first, there are a few things i would knock off your list. I would not go with the AEM cam gears, stock are fine, if you plan on building your head, the go with them, but if your leaving the head stock, don't worry about it. The UR pullies, don't do it, they honestly don't give that much power. Nology wires have been explained. The short throw, I would never chance a nice turbo motor to a short shifter, just not worth it to me, not to mention, you're not gonna shift that much faster. Everything else looks good though. On your setup at close to 15psi, i would guess, around 300-350whp.
