Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 09-23-2008, 07:23 AM   #1
wtijr
Turn off Running Lights
98 Regal LS
Is it possible to turn off the running lights? If so, how would you do that?
Thanks
wtijr is offline   Reply With Quote
Old 09-23-2008, 07:46 AM   #2
BNaylor
BNaylor's Avatar
Re: Turn off Running Lights
Assuming you are referring to the daytime running lights (DRL). The easiest way to disable DRL is you can remove the fuse marked DRL located in the passenger side fusebox of the dash. However, you will lose the auto headlight function and then will have to manually turn the headlights on or off.
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 09-23-2008, 01:47 PM   #3
wtijr
Thanks, that's exactly what I needed to know.
Old 11-07-2010, 08:56 AM   #4
bluezxracer
I tried this, and the car wouldn't start. Did I miss a step?
bluezxracer is offline   Reply With Quote
Old 11-12-2010, 04:46 AM   #5
mn_1
What say you BNaylor?
mn_1 is offline   Reply With Quote
Old 11-12-2010, 11:09 AM   #6
BNaylor
BNaylor's Avatar
What year Regal? Did you pull the right fuse?
Timeslip 08/12/06
Old 11-14-2010, 10:00 AM   #7
bluezxracer
98 Regal GS.
I want to apologise for posting in an old post. I did try this again, and it did work .
Thank you all.
Old 12-22-2010, 02:51 PM   #8
accuab
accuab's Avatar
Does this also work on a 2001? I looked in the passenger side panel and under hood panel but did not see a fuse dedicated to drl.
'01 Regal GS
accuab is offline   Reply With Quote
Old 01-06-2011, 12:01 AM   #9
accuab
accuab's Avatar
I asked once before but with no answer, but does this work for a 2001 regal? I could not locate a fuse dedicated to just the drl feature.
'01 Regal GS
Old 04-13-2015, 12:22 PM   #10
puff501
I have a 98 buick regal and all I did was pull fuse 13 in the right panel fuse block. DRLs went out and it also disabled the automatic headlights. Both problems solved with one fuse pull.
puff501 is offline   Reply With Quote
