Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Nissan
Primera | G20
> Engine
View Full Version :
Engine
Pages :
1
2
3
4
5
Engine Temperatures...
Hey Shaun (zykotik) - again with the tranny swap
Best Setup?
new ecu?
Hotshot Turbo?
Weapon R Intake for G20...
Glasspack Resonator
I want Intake, JWT Pop has pipe or no? I want pipe, any Intake I can get with it??
Fuel Pressure
George do you now how much is capable the roller rocker motor rev?
Exhuast??
Hotshot header & Place Racing CAI
2.25" turbo exhuast?
Reset Comp?
how much does a JWT Air filter go for?
Ecu
Hotshot Or Place Racing Cai
Advancing ignition timing
Brullen Exhaust
Pacesetter header and resonator
anyone have problems with purolator oil filters?
what happened to my engine?!?
Transmission Whistle/Siren noise
OEM exhaust mandrel bent ???
Affect on performance (change wheel size)
does anyone have a turboed auto trans?
Stillen Header
Just Changing the Exhaust headers?
Shops in the Los Angeles Area??
Grinding a new profile onto the stock cams?
I want an exhaust
Engine Break-In
Adapter for Air Filter
Turbo ... bo... bo..
Z32 T25 Turbo
most power with least amount of noise
how long....Sr20det???
JWT Roller Cams
Air Horn Install???
Ecu Code????
tranny seals
Turbo charger or super charger?!?!?!
Greddy Evo Exhaust
Dual tip exhaust?
BKR7E -vs- PFR6B-11
What type of ABS is on G20s???
Oil Pressure Gauge Hook-up
motor mounts for p10
Short Shifters?
Weapon R Dragon Intake
Autometer Gauge
Sunny GTi-R Gearbox
1/4 mile times
Battery Relocation Kits???
Radiator Problems??
Pics Of Intakes In Any G20!
exhaust systems
Roller-rockers?
HS Turbocharger
HS CAI Prices
SR20DET ECU wiring diagram needed
RandomTech Cat?
Limited slip diff stuff
replacing the ECU with a different spec one?
P10 Greddy Evo
Pulsar GTi-R sr20det
Swap Question a Lil Off
Hose Technique
level 10 on G20?
P10det are still there i need help
Intake Questions
Engine Swap
Energy Suspension engine mounts for our G20s
does "TORNADO" really work?
p10 CAI
hotshot header
Fuel Pump swap
Problems with DET Swap
Mufflers?
HS CAI vs JWT Pop
Pulsar/Sunny ever have 6 speeds?
Exhaust Manifold
How to make a custom intake pipe for P11
New Exhaust Installation- Chain or Local shop ?
gaskets?
'91 Cams in a '99 P11?
P11 Greddy Pics?
Changing the stock cams. What about the ECU?
370cc Injectors??
Finally got the HS header and CAI installed
Differences in ECU between '91 & '96
resonator and header
Times for a SR20DET P10
Ecu Codes
How much power can standard mod bring you?
header or exhaust?
Want to install intake...what to do with sensor?
Super AFC on a SR20DE
Headers
My intake won't fit
Does The Aem Fit In A P11?
TSB on Recommended Oil for SR20
Clutch Job
NOS wet vs dry
Getting the G20 to 200 hp
mystery part
Transmission change.
Max Hp
Can you do this to get more air?
Must be the starter right?
exhuast systems comparsion
earthing....some new tuners mod in japan
Quit Exhuast
Cobra MAF
Best exhaust of G20???
Octane Boosters
Calsonic radiator
Clutch Recommendations
breather filter for stillen intake???
Resetting ECU
anyone NOS their P11 yet?
Anyone know where I can get a Hotshot CAI for cheap?
ACT Clutch
Anybody care to share Greddy Exhaust for P10?
Cai
Question on turbo oil lines
Straight Pipe Exhuast? Yes\No
What oil ???
Haltech experiences?
auto to manual question?
Prolems: Static Noise at 5500 rpm in 2nd
New engine vs. adding turbo to current one.
2002 G20 Automatic 0-60
alchoul not to drink
Going to look at a motor
jwt or stillen cams?
George/Luke - Pick yer brain please
reset ecu
P11 G20 w/ QR25DE swap... @*#&!!!!
Question about installing new exhaust
Home made CAI
Custom 2 1/4" cat-back installed!!! Woohoo!
Q for George
Check out these muffler tips
What are the best spark plugs for the G20?
? Are there any diffrence in engine 99,00,01,02
what's a good clutch
RWD DET's
diferens between HSgen3 -4
Confused
lighting flywheel
AWD DET ??'s
A definate MUST!!
det changeable parts
Altitude calibration?
How to clean engine???
Unorthodox Pulleys
Glasspack as a resonator ???
Reactive Filter
Stillen Header
Will this CAI fit P11!
2000+ Cams??
Sr20det in a Datsun 510!!
to 22det
4 5Zigen exhaust applications for the P10!!
4WD 0-100 Time
question about the 99-00 compared to the 2002 limited Sport package.
engine misfire
Prices HS header (gen4) UR pullies (2set)
Camshaft and Injection
Custom Exhaust or Greddy...?
I Need This!!!!
Early Sr20de Ecu And Wiring Harness!!!
Custom Exhaust Shops - Columbus OHIO
which one is cheaper?HS or PR
tranny
Quarter mile performance
Custom Exhaust Pipe tubing for P10
Header
Q for Luke
Bkr7e
How much bhp?
Questions for the DETers
CAI /air condition ducts
msd ignition vs stock ignition
Who's G20/Primera has the most horses?!?!?
Hotshot Turbo Kit
Help
New Info on JWT Turbo Kit
Finally!!!
Tip size, will it fit?
Cam shaft fun!
This is what Place Racing wrote back!
To Ti423
Cutting Tip of Greddy Exhaust...
What Capacity
To George Roffe
'91 P10 G20 Cold Air Intakes
What do you think
What is this?
Stillen Muffler
$190 NEW OBX Headers... ...worth the $$$$
Intercooler Piping
92 hotshot cai
gear ratios
Anthony I need your help....
2000+ Hotshot CAI...
Exhaust options?
SR20DETs in Montreal
apexi s-afc
Woohoo installed me an intake :)
Random Tech Cat
Heat sheilding for intakes
Hotshot Header
P11 Greddy Cat-back
OBX mufflers?
2000 strut bar??!??!
ported head
Onorthodox pulley set
Splash guards
SuperSprint back box
RPM / engine rev
cold air intake
Aluminum Housing for Intake!!!!
I need a new clutch???
quickest g20
Good QUIET perfomance muffler?
Intercooler
JWT POP vs. STILLEN POP
pop charger/ filter info/help
P10 exhaust
cams-good or bad?
Has anyone heard of TODA
Exhaust manifold
AEW CAI for 2000 G20??
Better than a DET Look!
ECU resetting...
JWT and Hotshot?
What should I do???
1999+ Model Turbo??
SR20DEturbo $$$$$
power, reg, comfort switch question
Hotshot or Place Racing CAI
ebay intake question
Something wrong with my tranny...
P10 Automatic Motor Mount Question
KN Filter ... worth it or not???
Best INTAKE FOR G20
Primera header
chips for p10?
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
