Old 04-24-2003, 01:31 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
what is port
how do u port polish a head..like what is being polish and ported on the head..need to know....
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 04-24-2003, 02:06 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
port and polish is done to the head of the engine and makes the intake and exhaust ports larger so that more air can get cramed in the cylinder. Now it's more complicated than it appears because they help airflow and everythign so it's not just like make the port larger and go, it's complicated but i don't know all that much sorry.
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 04-24-2003, 06:51 AM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
porting is taking the gaskets for the exhuast and intake manifold and opening up the ports on both sides to match up to the gaskets...
polishing is smothing out the rough egdes on the ports so the air can flow better
Julian
Old 04-24-2003, 07:13 AM
91civicDXdude's Avatar
contrary to popular belief, it will not help your engine to make the intake / exhaust manifolds be the same size as the ports on the engine. you want them to be stepped both ways to help reversion and scavenging. you want the intake manifold to be smaller than the intake port and the exhaust manifold to be larger than the exhaust port.
the areas that would benefit from a port are quench areas where the ports get too small, or porting the manifold themselves such as when u use a bigger throttle body. There are many misconceptions to port & polish. Even though you can help out a little by smoothing the rough edges, generally porting a honda head should be left to individuals with a flow bench which can determine if you are actually makin the flow rate better, or just enlarging the ports which can bring the velocity of airflow down.
Old 04-24-2003, 09:13 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
preach on brother man...that was a damn good descripition of port and polish.......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
