Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 04-23-2003, 01:54 PM
Fritz The Cat Fritz The Cat is offline
302 oil pressure question
1986 302 w/ 160k miles. Loses oil pressure at idle after driving approx 10 miles. Rev engine to about 1500 rpm and hold it there, pressure builds back up. Oil & filter change w/ 10W30 gives no improvement, oil & filter change w/ 20W50 cures problem for 100 miles, then the pressure starts dropping again. In your opinion, oil pump problem or bad bearings? BTW, when pressure drops, I do not hear any lifter clatter.
Ashes to ashes, dust to dust,
If it wasn't for FORD,
All my tools would rust.
Fritz
Old 04-23-2003, 02:27 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
Is the engine all grungy inside? maybe it needs to git flushed.
Also it'sa cheaper to stick on a new oil pump than a new engine.
Old 04-28-2003, 10:26 AM
450HPviper's Avatar
450HPviper 450HPviper is offline
Good point, try a new oil pump first.
Old 05-12-2003, 07:13 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Are you going off the stock gauge still? When pressure drops by how much are you talking? I would really suggest getting a more accurate gauge to monitor the exact oil pressure.
You have a 160k miles motor, it's going to start showing signs of wear. Low oil pressure can be associate with bad or warn bearings. As long as you don't get lower then 15psi, or spikes to 0, I wouldn't worry about it too much. Since you said pressure builds back up as rpms increase, things still sound ok.
Remember this; As oil heats up it thins out, and as oil thins the oil pressure will drop. Now a motor oil like 20W50 is a lot thicker, and will create more oil pressure cause of its consistency. But like any oil it will thin as the oil heats up. Since you motor has 160k on it, and you have oil pressure problems, I would start to run a heavier weight oil to withstand the clearances the motor now has cause of wear.
One other thing. Oil pumps are no fun to change, and I don't really see that as your problem. From what you described, everything sounds right for a motor with high miles on it.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 05-12-2003, 07:28 PM
On the stock Ford truck style gauge, after 10 miles driving, when I stop at a light, the gauge will drop all the way to the left indicating no oil pressure. This is with 20W50. One thing I don't understand, if the oil pressure is that low, shouldn't I hear lifter clatter?
Fritz
Old 05-13-2003, 07:02 AM
HiFlow5 0's Avatar
Stanger
So it only drops that bad at an idle? When cruising it's good? I would get an aftermarket gauge, something cheap, but good enough just to get a more accurate reading. The stock gauge will drop off after pressure reaches a certain level. So in reality you might have, say 5psi, but the gauge will read 0, that's why you don't hear lifter clatter.
How does the rest of the truck run?
-2013 Ford Flex
-1999 Ford F150
Old 05-13-2003, 10:35 AM
Everything else is just fine. Allways starts up, runs like a champ. The only real problem I've ever had with it was the time the fuel pressure regulator went out, what a mess, gas everywhere. Even the air fiter box was soaked. I just wish Fords didn't rust so bad.
Fritz
Old 07-14-2003, 01:07 PM
Bize Bize is offline
Same Problem
Fritz the Cat, i have the same oil pressure problem in my 92 302 5.0 , i am getting a new oil pump done today, did you resolve your problem, and how, maybe i can let you know if this worked for me, please send me a email @ [email protected] thanks
Old 07-27-2003, 01:33 AM
vbrpete vbrpete is offline
Change your sending unit first(lower right side of the block,above the oil filter-looks like a bell with a wire on top) or better yet,get a REAL,mechanical o.p. gauge.Ford OP senders are crap.So are their gauges.Especially tachs on 5.0 Mustangs.Mine was out almost 800 rpm from what THREE aftermarket tachs read.
Old 09-13-2003, 10:44 PM
IDAHO JOE IDAHO JOE is offline
302 low oil pressure
Hi:
I drive all over the NW for work and this truck is great. It is just shy of 300,000 miles and runs like a champ. The oil pressure always reads right in the middle of normal, but last week it dropped below the "N" in normal but no where near low or danger.
I keep this rig in pretty good shape and am getting concerned. I know it has 300K, but my last 302 made it to 475K, so I have a long ways to go. I gather from the messages here that the best way to go is:
1] replace sending unit
2] check pressure with a real gauge.
3] clean pan and intake tube.
4] change oil pump
5] drive it til she drops
6] new engine
BTW there is no lifter or engine noise at all and it is not
that serious now, but why wait for something serious?
Any comments, and has anyone had luck in regaining pressure
from changing the oil pump?
Thanks,
Joe
Old 10-29-2003, 08:40 AM
olered olered is offline
Send a message via AIM to olered Send a message via Yahoo to olered
Re: 302 oil pressure question
i had the same problem with my 302 in an 88' f150 i changed the oil sending unit that screws into the driver side of the block and fixed the problem
Old 01-12-2004, 06:12 AM
pontchief's Avatar
pontchief pontchief is offline
Send a message via ICQ to pontchief
I have a 89 bronco with 302 with the same problems. It's ok until the engine gets warm , but then it drop.There is no bad noise to hear fro the engine.
I have changed the oil pressure unit.But the problem is still there.
The engine has only 78 000 miles on it.
Old 05-14-2004, 02:17 PM
n2racing n2racing is offline
Mains?
Try revving the engine to about 2000 rpms. If you feel a vibration the mains are weak. I have discovered this situation many times in the past.
Old 11-24-2004, 02:41 PM
Bronconeedshelp Bronconeedshelp is offline
Re: Re: 302 oil pressure question
I have the same problem 89 Ford Bronco with 302. The oil pressure drops when I come to stop after the truck warms up. The oil pressure drops all the way down and the engine light comes on. What do I do?? I love my truck and I need help.
Old 11-24-2004, 03:04 PM
pontchief's Avatar
Re: Re: Re: 302 oil pressure question
Hi
The problem was crank and bearings.
Regards Per Arne Sund
http://spirit-of-america.biz/
'98 Regal.... no oil pressure after changed oil Mr_D Regal 6 04-06-2010 12:08 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
No oil pressure on my big block 454BLAZER Problem Diagnosis 10 05-22-2009 12:37 AM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
