Old 04-23-2003, 12:18 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
need help......
how do i get the timing belt back on the cam gear on a 4th gen accord? it is an lx with the f22 engine
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 04-23-2003, 09:03 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
..I"m guessing you have to go in and loosen up the tensioner to get a little slack?
SOLD!
Old 04-23-2003, 09:18 AM
where is the tensioner at?
Old 04-23-2003, 09:20 AM
marked001's Avatar
Moderadur
...take the wheel off...look at the tbelt cover...there should be a piece of plastic that can be popped off...not really sure..just thinkin its the same as a civic
hit up the accord forum at www.honda-tech.com ...I'm sure they'll be able to help, since the accord forum here is dead...
SOLD!
Old 04-23-2003, 10:13 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Yeah you have to loosen up the tensioner, when your looking that the cam gear if you look down on the lower timing belt cover you will see a black rubber plug, pull the plug out and there is a 12 0r 14 mm bolt undo it a twist or two, oh the bolt you can't really see because it sits kinda inside the cover, don't undo the bolt all the way either just a few turns, than put the belt on the cam gear, you will have to work it on. After the belt is on turn the crank a bit to get some tension on the belt and snug up the bolt for the tensioner that you loosened and your done.
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
need help removine vent on passenger side of dash in 94 accord? need help on removing 94cordvtec Accord/TSX/Accord Hybrid 2 01-23-2005 09:50 PM
Help Help Help!!!!! Need Help! shahram177 Off-Topic 12 11-09-2004 07:22 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Need Help On What Glue I Need For Body Kit Installation....HELP PLZ!!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 8 08-13-2002 08:24 PM
