Old 03-25-2010, 09:51 PM
quadtrac quadtrac is offline
04 Silverado max tire size?
I have an 04 silverado 4x4 truck with the 17" wheels on it, when I buy new tires I want to get some bigger tires. Does anybody know what size will fit? By the way it is a z71. Thanks
Old 03-27-2010, 07:38 PM
mcdave71 mcdave71 is offline
Re: 04 Silverado max tire size?
Stock is 265/70/17. You can easily go to 285/70/17 with no problems. Go bigger and the cost gets way up there and you start scrubbing. You might want to level the front end when you do tires if you haven't already. Usually needs about 2 inches to match the back. You can try cranking the stock keys or install leveling keys. Be sure to have the front end in the air when you tighten the key bolts to prevent stripping threads. If you only raise it two inches, you might get away without a front end alignment.
Old 11-26-2010, 01:52 AM
bmstepan's Avatar
bmstepan bmstepan is offline
285 65 18
you willl have to trim a bit of your wheel well liner up front but it will fit nicely only rubbing a tad on tight turns
Old 11-28-2010, 01:46 AM
bigbadram51 bigbadram51 is offline
I ran a 305/50-20 on a 8.5 inch wide wheel before my lift... Tire size will be solely based on wheel choice, the more backspacing the bigger tire you can stuff in there. As stated with a crank or leveling kit you can easily fit a 33"
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
