Old 03-25-2010, 06:45 PM
Tiara_270 Tiara_270 is offline
Trick I learned to replace seals
I would like to share a trick I come up with, maybe someone else has done this before and I missed it. It took me about 20 min to change the leaking seal on my front cam seal and I will be trying this on my lower crank seal when time comes.
Took a sharp punch and centered it in the front of the seal and made a small impression on the seal. Then took a small drill bit and drilled a small hole in center of the ring portion of the seal. Took a small screw and screwed it into this hole, pulled screw with pliers and she popped right out!! Warning do not drill into the seal surfaces, I will post a pic soon as I get my home computer up and running.
Old 03-26-2010, 05:58 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Trick I learned to replace seals
I just replaced the crank seal on mine and took pictures. Used the screw method also. Here is the thread........
http://geometroforum.com/topic/3083546/
Old 03-26-2010, 11:46 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Self tapping screws work well also. They eliminate the punch and drill which can be handy if the spaces are really tight.
Old 03-27-2010, 08:26 AM
Thanks, same screw method works great! Do you have a thread for the distributer oil seal? I found doc's thread for the purchase of the O ring but not the replacement steps.
