Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-29-2001, 05:43 PM
RALMADA RALMADA is offline
Keyless entry programming, Max 1999
Does anyone know how or where on the web, can I get the programming instructions for the transmitter of the keyless entry of a Maxima 1999?, Lost mine, a friend sold me his spare, but need to make it work!
Old 10-29-2001, 10:57 PM
Ravq Ravq is offline
I'm not absolutely certain these instructions will work for your 99 but maybe it will. This was taken from http://web2.airmail.net/scutchen/max_faq/
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock knob.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 10-31-2001, 11:07 AM
Thanks, worked just fine
Old 10-31-2001, 01:44 PM
MaxRX7's Avatar
MaxRX7 MaxRX7 is offline
ID code entry:
NOTE
yes, I know, just whoring through... :flash:
Maxima parts for sale:
http://home.comcast.net/~luisrx7/MaximaParts.htm
Old 10-31-2001, 04:39 PM
You're welcome.
