Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 10-29-2001, 04:51 PM
NismoPC's Avatar
NismoPC NismoPC is offline
P10 Oil Pressure Switch Upgrade Info - A must read!
Ever wonder where that freakin' oil leak is coming from?
Never found it!
Probably your Oil Pressure Switch. It is located above the starter right above the oil pan towards the passenger wheel well. You have to get way up in there to see it. Looks like the top of an O2 Sensor.
If you have not replaced your oil pressure switch on your P10 and are experiencing the above symptom, make sure you buy the newest Oil Pressure Switch to replace it.
The old Nissan Part#'s are:
25240-89920 or 25240-89915
And are the same in the SE-R's, NX2000's, 200SX SE-R's, etc.
The alternate upgraded Nissan part # is 25240-89960.
I spoke to the local parts guy at a Nissan dealership when I purchased mine and asked if this is a common part that they go through/replace. He stated that it was and that Nissan had made the newer one stronger to withstand the common leaks. He stated the replacement rate has dropped significantly since the newer one was released.
NOTE: I do not know the date when Nissan began to offer the newer part, so this might also be a common problem with the P11 as well.
I will try to post pictures of the actual location of the switch, the old switch and the new when I replace mine this weekend.
Brandon
'96 G20 - modified
Old 10-29-2001, 07:57 PM
P10DET's Avatar
P10DET P10DET is offline
Re: P10 Oil Pressure Switch Upgrade Info - A must read!
Originally posted by NismoPC I will try to post pictures of the actual location of the switch, the old switch and the new when I replace mine this weekend. [/b]
There are several photos of the location on my website in the Beast articles.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-29-2001, 08:24 PM
AWD Primera's Avatar
AWD Primera AWD Primera is offline
Re: Re: P10 Oil Pressure Switch Upgrade Info - A must read!
Sorry for my ignorance but what is the address of your website?
Old 10-29-2001, 09:11 PM
NismoPC's Avatar
Re: Re: Re: P10 Oil Pressure Switch Upgrade Info - A must read!
Click on the link at the bottom of his post that says Homepage
or just go to:
http://home.earthlink.net/~geo3/
Hey George. I just looked around at the SE-R link and the G20 link and could not find a shot of the oil pressure switch. I saw a shot of the sending unit, but that was it. Did I overlook a pic or two?
Brandon
'96 G20 - modified
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
