Old 04-20-2003, 05:29 PM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Uses for a Dremel Tool
Since my bdays soon (27th) ive requested a Dremel Tool from my family, as a present.. and i know it has many outside uses, but im wondering What i could use it for, dealing with models???
sand bodies?
Old 04-20-2003, 05:48 PM
BaNe BaNe is offline
I would also like to know this.
Old 04-20-2003, 05:49 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
You can chop up bodies...remember the thread about how to sand tires with a drill? You can probably do the same with the dremel tool. There are a bunch of otehr things you can buy for your dremel also.
I hope I helped
Old 04-20-2003, 05:53 PM
mentel's Avatar
mentel mentel is offline
Racing Forum Moderator
Send a message via ICQ to mentel Send a message via AIM to mentel Send a message via MSN to mentel Send a message via Yahoo to mentel
Drilling holes for spark plug wires.
Drilling holes for brake rotors.
Cutting off parts
Sanding parts.
Put your rim on a drill bit, take a glove and sandpaper and sand the tire (put on glove to avoid burning ur hand from friction, wrap sand paper around tire and put dremel on low speed)
you can get big buffer attachments , low speed setting and a light touch will giev you a shiny surface with the right practice
can use dremel to work on metal kits, sanding them with special bits.
list goes on and on
Old 04-20-2003, 05:59 PM
Drilling holes to make body-kits, cutting THICK styrene, you'll find so many uses for it! It's a good investment, and if you get one for a gift, you're pretty darn lucky! Make sure you get a varible speed one, this way you get more speed choices!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 04-20-2003, 06:05 PM
Lownslow's Avatar
Lownslow Lownslow is offline
20% of work i do with model cars involves a dremel
Old 04-20-2003, 08:38 PM
Everyone I know this wasnt my original post but I thank you all
Old 04-20-2003, 08:41 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Just be sure to know where your hands/fingers are at all times!
Old 04-20-2003, 08:46 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
HAHAHA
if i told my parents thats what i want for my b-day present... they will think i am nuts or somthin
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
