Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-20-2003, 02:25 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
Installing coilovers on a 90 integra? DIY or not?
I want to lower my car with coilovers.. is this a do it yourself type of thing or not? can someone give me a link to a site that explains in detail with pictures how to remove the stock springs and put on the coilovers?
Old 04-23-2003, 11:14 PM
Vtec Vtec is offline
This is a do it yourself type thing but seeing how its your first time it's gonna take a while. You might need a spring compressor depending on how you undo the shock I undid mine from the top under the hood without a compressor kinda dangerous cause the spring could fly off and cause some damage. I've done my last 3 cars that way never had any trouble it just drops down. It's all pretty straight forward once you get the wheels off you can pretty much see what needs to be done to install the springs, each spring is marked so you know which ones go in which corner or which goes on the front and which goes on the back.
Old 04-25-2003, 02:59 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
u really don't even need a spring compressor. jus shoot the end into something solid (ie empty garbage can...etc..) jus have a frien hold the side of it an make sure to wear gloves. really is pretty simple, jus take ur time an keep ur cool.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 04-25-2003, 03:42 PM
90gs's Avatar
do you like pop the hood and undo the nut at the top of the strut then unbolt it from the axle then what from there? once i get the stock spring off im sure i can figure it out from there as far as putting on the new coilover assembly
Old 04-29-2003, 01:51 AM
teck teck is offline
Send a message via AIM to teck
do it youself for sure use a spring compressor if you don't want to mess your fingers up
check out my ride at:
http://www.cardomain.com/id/civs2000
Axis MOD 7's 18" - S2000 tailight conversion - Antenna, trunk & moldings shaved - APR mirriors - molded black widow 2 rear - Tokico Gas Shocks - Skunk 2 Coilovers - ALPINE CDA-9855 - iPod Adapter - Deck - Pioneer Digital EQ Hifonics - 1000w Alpine-600W Subs-12" Kicker Comp VR - 2 7in. visor t.v's - 2 12 in. t.v. on my roof heh
Old 04-30-2003, 02:41 AM
90gs's Avatar
where do you get a spring compressor and how much do they cost?
Old 04-02-2004, 11:37 AM
micray83's Avatar
micray83 micray83 is offline
Re: Installing coilovers on a 90 integra? DIY or not?
You can rent them at Autozone or Pepboys for free. You can also buy one for around $20 - cheap. Check eBay for some: http://search.ebay.com/search/search...ing+compressor
