Old 04-20-2003, 11:00 AM
Parker Parker is offline
ok, which type of box?
I have a civic hatchback, and i am about to build a custom fiberglass enclosure for 1 10" to replace one of my rear interior side panels. my current debate is whether to make the enclosure vented or sealed and if vented, what type of port to use. i am very interested in sound quality and volume at the same time, and i have seen vented enclosures that have good bass response and dont sound too boomy, but i have also seen sealed enclosures that will hit very hard and still sound good. does anyone have any good advice on this matter? i currently have a self-made box for my rockford HE sub with all the power available it could ever want, but im looking for a little more by the way of spl while still keeping my accuracy
Old 04-20-2003, 02:39 PM
CivicSkater CivicSkater is offline
Banned
I would go with ported. I have bandpass in my car, but i would still take ported over sealed.
Old 04-29-2003, 07:39 PM
redmanjd redmanjd is offline
it really depends on what type of music you listen too
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 04-29-2003, 10:16 PM
LiLJami LiLJami is offline
Send a message via AIM to LiLJami
I work in a car audio store and am an installer. The worst thin gabout a ported box is that you can get real bad port noise at times. A ported box is definately gonna be louder and more boomy but thats not necessarily a good thing. I guess what you need to figure out is if you are leanin more towards sound quality or just the loudness.
See Pic of the truck here!!!
Email = [email protected]
AIM = liljami95
Old 04-29-2003, 11:43 PM
sublimewls sublimewls is offline
Send a message via AIM to sublimewls
i ain't a professional... but i had a 15" ported and it boomed... but it was "sloppy"... if you are looking for clean i would say sealed...
: 1995 civic EX coupe
Mods: Pioneer P4300 Deck, 2 MTX Thunder 4000 Subwoofers, MTX Thunder4242 2-channel amp, tint, clear corners, peeling blacked out tails, newly painted steelies
Future: Coilovers, 16" gunmetal motegi mr7's
Old 05-03-2003, 07:46 PM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
I second a sealed box. They sound good no matter what kind of music you listen to.
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 05-04-2003, 03:32 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
I like ported boxes, which is why I got the Bazooka tvb 141 box, that thing has excellent sound quality (to me at least) and no port noise since it was all designed to work together.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-04-2003, 12:29 PM
turbcivic's Avatar
turbcivic turbcivic is offline
A ported box can sound just as good as a sealed box if down right. A ported box requiers more airspace then a sealed and is a little more difficult. Tune the port down to about 29 hz and that will tighten up the bass a little bit so you won't have that sloppy sound. Port noise is a nother story. Ideal port velocity is 25 m/s, use a program to find the velocity. It also helps to router all the edges of a port. A whistle works because of the sharp edge and the sae holds true to a speaker box.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
