Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 04-20-2003, 06:48 AM
udm98 udm98 is offline
1997 LHS keyless remote
Need programming instructions for programming a 1997 LHS
TRW keyless remote...
Old 04-27-2003, 09:27 AM
I finally figured it out...Anyone else needing help with this here ya go!
1st insert key and turn to on position but dont start engine
2nd look under driver side dash for the data link connector ( just looks like a plug) look for connect pins 1 and 4 then get a jumper wire and jump pins 1 and 4 together. you will hear the horn and the doors will lock. While the pins are jumpered press your unlock button on the remotes you want programmed and the doors will lock and unlock.
3 lastly remove the jumper for pins 1 and 4 and your finished ...
Hope this helps some of you ....
:smoka:
Old 04-20-2004, 08:25 PM
araich2 araich2 is offline
Question IS 96 transmitter installation same as 97 or 95?
Is 96 Lhs transmitter installation same as 97 lhs or 95 lhs?
Thanks
