Old 04-19-2003, 06:21 PM
blazer91 blazer91 is offline
2000 blower motoer speeds
Hi I have a 2000 Grand Am Gt that the lower blower motor speeds do not work I think its the resiter but I can not find it is the blower motor under the dash because the firewall is flat and there is nothing on it
Norm
Old 04-29-2003, 09:39 PM
avenger851456 avenger851456 is offline
I had the same problem on my 99 grand am se, it was the resister, on warenty at time so I did not fix the problem myself but that's what it sounds like.
just trying to get the most out of my grand am
Old 08-14-2003, 07:05 AM
gakman gakman is offline
2000 Blower Motor
I have the same problem. Where is the resistor located?Do you have to replace the whole blower motor?
Old 08-14-2003, 09:38 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The resistor is mounted forward of the blower motoron the passenger side underneath. You will need a 5.5 mm socket and a short extension. It is a real bear to get to all 3 bolts.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 09-05-2003, 10:22 AM
PT_Sean2 PT_Sean2 is offline
Re: 2000 blower motoer speeds
Wow- great news. My wife's 99 G.A> has the same prob- no LOW SPEED fan (lowest 2 settings). I swapped the high and low relays and fuses, still nothing. Time for the R swap.
The dealer wants $35 for the part, seems high for a reisistor. Any idea if this is a ceramic high power R or a Radio Shack replaceable, or even a repairable item??
Thanks btw- great info.
Old 09-05-2003, 06:02 PM
Flatrater's Avatar
Main GM Guy
Re: Re: 2000 blower motoer speeds
Its not a Radio Shack part!! It is 4 resistors mounted together. Usually it is burnt up, you will see this when you remove it.
ASE Master Tech
ASE Advanced L1
GM Master tech
Old 09-05-2003, 09:07 PM
Removed it- took the blower out (3 7/32 screws) then the resistor board- its actually a resistive trace etched onto a printed circuit board. There was some corrosoion and the traces GONE along the thinner, outer trace, the LOW speed no doubt. The inner THICKER trace must be for the high speed. I jumpered the breaks with wire, and got it to WORK!! I am unsure if the heat that is generated is too much for the 27W solder that I used so I will replace it.
It is easier to remove the resistive circuit if you remove the blower, the back screw (there are 2 on the resistor) is hard to get at otherwise.
Old 09-08-2003, 07:57 AM
Well- all fixed. The NEW resistor board is now TOTALLY COATED and CORROSION PROOF! It should have been that way from day one IMHO!!
The resistor went back in easily (2 5/32 screws), the blower went back in (3 screws), the BCM and a light (1 screw), then the HARD part was re-seating the left-most panel, which has heating ducts. You have to line up a hose from above, AND a duct opening on the left, which goes inside its mate, then line up the 3 1/4 screws with their holes. The right-most trim piece snaps back is and is set with a push/flare plastic nut.
Cost- $31.45 Cdn (new part- part number is at home, sorry)
Time- 2 hours
Tools- 5/32 socket, 1/4 socket. 1/4" drive, 3" extension, flat screw driver, needle nose pliers
Thanks for the help here BTW- you have made my wife, and I , very happy!!
Now to tackle the TRAC OFF light, and the CRUISE button not working problems. Sheesh.
Sean
Old 09-08-2003, 07:12 PM
Flatrater's Avatar
Main GM Guy
Time- 2 hours
Dude I get paid 8 dollars American to fix that at work!!! Can I send you a bill?
ASE Master Tech
ASE Advanced L1
GM Master tech
