Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-25-2010, 01:30 AM
Syberfinder Syberfinder is offline
1996 Jeep Grand Cherokee Suspension Question.
I recently went through a section of bad Highway with my 96 Jeep Grand Cherokee, when I hit a couple of abrasions in the road at about 55 MPH and went on to smooth Blacktop my Jeep continued to jolt like I had a flat tire. I slowed down to 40 MPH and the vibration stopped and I was able to continue down the road. I figured this was a sign that my shocks were warn out so I replaced them all. Now again today I had this same thing so it wasn’t the shocks. Has anyone any idea what I need to look at next?
Thanks
Old 03-25-2010, 06:23 AM
jeeppyfan's Avatar
jeeppyfan jeeppyfan is offline
Re: 1996 Jeep Grand Cherokee Suspension Question.
Is it on one wheel in particular or more than one? Did you check coil springs while replacing shocks? You may have one broken. If coils are OK and if you suspect one wheel, rotate wheel with another one to see if problem remains or follow. You may have lost a balance weight on the wheel. I may be wrong but that's where I would start.
Old 03-25-2010, 05:31 PM
I may take it into the tire shop and have them take a look down there. The springs are not broken. Thanks for your assistance! I will post the findings from the tire shop when I figure out what the heck is up.
Thanks,
Old 03-26-2010, 11:55 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Check to see that the balancing weights are still on all 4 tires...
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-26-2010, 07:20 PM
Bluleader Bluleader is offline
I had the same problem on my 93 Grand. I re-balanced all the tires and checked the wheels, had the front end completely rebuilt for a cost of over $800.00. Problem still happened, then I noticed a shock absorber lying sideways up front, It's a dampener. designed to absorb the shock between the wheels. I replaced it, problem GONE!!!!
Old 03-27-2010, 01:54 AM
When I replaced all of the shocks I tried to replace the steering stabilizer too but could not get it off to replace it. I will see if I can get the tire shop to replace it for me while I am having my tires checked.
Thanks,
Old 04-02-2010, 02:53 AM
Okay, Here is the fix. I could not get the steering stabelizer off to replace it so the tire shop did it for me. It cost $85.00 and fixed the problem. They told me if that did not fix the problem the only other thing it could be is the "Track Bar" and they would be happy to fix that for about $200.00. So if it is not one it's the other.
Thanks all for helping me figure out the problem!
Old 04-02-2010, 05:03 PM
YW. I learned from experience on that issue. My alignment man had replaced the entire front end to no avail. Then the tire shop rebalanced all the tires dynamically, (as opposed to statically), and replaced all the rotors etc. Still had the problem. So when I replaced the stabilizer, BINGO!.
Old 04-02-2010, 10:01 PM
That's what makes the Automotive Forums so Good. You saved me money and time this time and someone will come up with an answer for your problem next time. We all work together to keep the cost down.
Thanks again BluLeader.
