Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 10-29-2001, 10:35 AM
g201996 g201996 is offline
fog light plates on p10
has anyone removed their fog light plates on their p10? by this I mean the two places where the fogs are supposed to be. i was going to just take a razor blade to them. i plan to just leave the space empty. is there anything behind there that would make it look odd?
:smoker2:
Old 10-29-2001, 01:46 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Well, one you wont be able to razor blade them becuase they are like 1/4-1/3 inch thick hard plastic...I had to use a dremel
Theres actually "two" sections of the foglight holes...the larger outer one, then the small inner piece. These are seperated by a "vertical split" you should see. If you just cut the outside portion, you wont see much but if you cut the inside too, you will see a braket type thing.
I would say not to cut them unless you are doing somethin with them...like setting up an air induction system for the brakes or whatnot. Better to keep the FOD outside the car.
-Brian Jones
I got a snake man
