Old 04-19-2003, 09:56 AM
dylly dylly is offline
Front End Coversion
I was just wondering if it would be possible to convert the front end of an older chev ck 89- 96 to a new style front 99-2002. If it is how should I go about doing it and what will I need?
Old 05-11-2003, 02:34 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
I get this question a lot at work and I always tell them that if you like that style save your money and buy one. Everything is different, Radiator, core support, hood, fenders, inner fenders, grill, lamps, frame. It will cost a small fortune to change it all. I am not even sure that it will all bolt together.
Old 09-13-2004, 11:31 AM
lonelywolf8588's Avatar
lonelywolf8588 lonelywolf8588 is offline
conversion reply
I have seen it done to a 98 dually to a 2000 2500HD conversion but the guy replaced the entire front frame and fenders had to be modified to match the styleline
Old 09-14-2004, 10:28 PM
lowgreen1 lowgreen1 is offline
You can look through a trucking magazine and get a aftermarket kit or you can get the good GM stuff. The Gm stuff will fit alot better and is better quality, it's a little higher but well worth it. It's all totally bolt on stuff. The only downfall with the Gm stuff is you have to fill in the fender flare holes. Here's the GM part numbers if you plan on going that route. HOOD 15053969 1
FENDER 15035791 1
FENDER 15053975 1
HEADLAMP 15738657 1
HEADLAMP 15738658 1
LAMP 15738665 1
LAMP 15738666 1
FILLER 15738332 1
FASCIA 12475244 1
CRASH BAR 15018545 1
GRILLE 12474498 1
SUPPORT 15738653 1
SUPPORT 15036422 1
BRACKET 15035967 1
BRACKET 15035968 1
PLATE 15548810 2
BOLT 11516460 10
WASHER 15531206 10
BRACKET 15743027 1
BRACKET 15743025 2
FILLER 12375170 1
FILLER 12375171 1
GRILL BRACKET 15019277 1
HEADLIGHT SOCKET REPLACEMENT 85881 2
Or if you want to be totally different get this 2004 bolt on escalde clip. Check it out here. http://www.fullsizechevy.com/forums/...d.php?t=116430 These guys over there have alot of knowledge when it comes to custom trucks. Check them out.
90 GC front end noise Selec-trak benjaminbunny Grand Cherokee | Grand Cherokee SRT8 1 12-20-2009 06:00 AM
Creaking Noise At Front-End el ratfink Pacifica 2 12-05-2009 11:57 AM
Front end noise Bob Moore Dakota 5 07-25-2009 04:40 PM
Clunk in Front End 97 Blazer Massguy Problem Diagnosis 3 07-05-2009 08:02 AM
Front End Metallic Clunking amesjm0431 Grand Prix 2 06-17-2009 09:17 PM
