Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 03-24-2010, 02:34 PM
jhall0705 jhall0705 is offline
99 Denali headlight assembly question
Ive had my Denali for 4 years now and i have never been able to change out my low beams. I understand that the headlight assembly has 2 pins to unscrew after taking out the turn signal lights....but only one pin comes out and the other one spins in place. Any suggestions?
Old 03-24-2010, 02:53 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 99 Denali headlight assembly question
The pins come out the top. You shouldn't have to remove the turn signals. Are you sure you aren't turning an adjuster screw?
Old 03-24-2010, 06:31 PM
I originally thought I was turning a headlight adjuster or something but it says remove the 2 pins at the top. Last year when I took it to the dealership for a tune up I asked them to replace my bulbs and will pay the labor. And they told me that they couldnt do it........needless to say that was the last time I took any of my vehicles back there for service.
Old 03-25-2010, 07:27 AM
yukon6inchlift's Avatar
yukon6inchlift yukon6inchlift is offline
i think u can get the bulb out w/out removing the head light. may have to remove the batt on that side to get to it. try a pair of needle nose pliers, lift up on pin while turning it. the adjusters are way down in a hole
Old 03-25-2010, 09:19 AM
You can access the high beams but not the low beams. I also thought of taking the battery out but I'm hellbent on getting the whole assembly out. I'm wondering if I should buy more bulbs (cause the one's I have are 2 years old) or get a resonable priced HID kit. Any thoughts???
Old 03-25-2010, 09:50 AM
yep, i got the zenon lifetime bulbs. the blue ones, got them on ebay. they do stand behind the warantee but u have to pay shipping. i also got new assemblies also ebay, the clear ones. they dont fit like oem, reveil is uneven and the one hits the turn signal but i made them work and now i can see at night
