Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-18-2003, 12:51 PM
rody084 rody084 is offline
breaking in new pads and rotors (more complicated than the title states)
hi,
I just purchased some new Brembo Blanks and some new AEM HP brake pads for my 1990 Integra.
My current rotors are warped and my brake pads are unevenly worn (top is more worn than bottom & inside pad more worn than outside pad).
I have been reading about how you are supposed to break in rotors and pads separately, but I was wondering if I break in my rotors with my old pads, will this cause the rotors to warp (since the pads are slighly deformed, we're talkin about 1mm at most here).
I was thinking of maybe putting my new brake pads on my old warped rotors and breakin in the pads and then puttin on the new rotors and breaking in the rotors with the new (recently broken in) pads.
what are your thoughts on this?
Old 04-18-2003, 01:41 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
You are supposed to break them in together. Whenever you switch to new pads you are supposed to get the rotors resurface so they will welcome the newer pads (since pads wear out quicker than rotors in most cases).
Do 5 60-0 stops medium pressure
And then do 5 30-0 stops light pressure
then let the car sit overnight.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 04-18-2003, 02:47 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
When I got my Power Slot rotors (as I'm sure you remember reading when you had yours) it states that you aren't supposed to make and sudden or heavy stops for the first 200-500 miles of having them on. I'm sure with blanks it's a little different break on proccedure, but would the 5 medium 60-0 stops be too much for the break in process?
Also with my rotors it says you have to periodically heat cycle them. What exactly does that entail to do?
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-19-2003, 04:53 PM
Civic Mod
I never read the directions and broke them in like I stated above
To heat cycle means to get on the brakes HARD enough to heat them up. I would figure this would bed in the pads again since Slotted rotors clean the pads everytime you use them, but they can also glaze your pads - turns them into glass.
Autocross Help Page
Buy my Civic parts!
Old 04-19-2003, 09:34 PM
Cali Guy
If my wheels are getting warm or hot from braking, isn't this like a constant thing anyways? Or what's different about it?
hessemer69 on AIM
