Old 04-17-2003, 08:02 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Hood alignment?
Hey guys what's up? I just got my new carbon fiber hood in and put it on. The only problem is it isn't level with the fenders. Also it has a larger gap on one side than the other. Anyone know how to adjust this?
Old 04-17-2003, 08:04 PM
GTA's Avatar
GTA GTA is offline
Whee..
i know there is a way to adjust it, just dont know how...
CF hoods never fit as good as a stock hood, but thats something most dont care about... i know i sure wouldnt
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-17-2003, 09:49 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
u have to put the rubber stops in on the sides like the stock hood, might have to do some cutting.. nuttin major
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 04-17-2003, 10:47 PM
hotasshonda hotasshonda is offline
Send a message via AIM to hotasshonda
to line up the sides w/ the fenders you can losen up the 3 fender bolts on the top of the fender (10mm). then just push it in and re-tighten it....that should help a lil bit.
Current Mods:
B16a, I/H/E, Coil overs, Shocks, Integra Front Suspension, Cross Drilled Slotted Rotors w/ Green Stuff Pads, Short Shifter.
**System**
Pioneer 6500 HeadUnit
MB Quart Component Set-Front
Boston Acoustics-Rear
Old 04-18-2003, 08:25 AM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Well, you said that the hood wasn't at the right level with the fenders? meaning that the hood is vertically higher than the fenders?
I had the same problem with my fiberglass hood, and the body-shop that painted it ended up making several cuts in the fiberglass support under the hood and stretched/bent the hood into shape and re-fiberglassed it so it fit perfect. Carbon Fiber though is a different story...
