Old 04-17-2003, 05:39 PM
slowCRXinPitt's Avatar
slowCRXinPitt slowCRXinPitt is offline
Unhappy striped bolts on hub! HELP!
Help! I took my old wheels off to install new ones and the bolts on the front passenger side were striped! I cant get anything on them and my car is blocking my driveway! What do I do?
Old 04-17-2003, 06:15 PM
91civicDXdude's Avatar
you should replace the wheel studs. try to clamp onto them with vice grips or something and turn them out. if that doesnt work, then cut the bolts off at the hub and get an easy out and drill and remove the studs.
Old 04-17-2003, 06:25 PM
Its possible to cut them off and replace them? where would I find replacements?
Old 04-17-2003, 06:31 PM
AlwaysMovin AlwaysMovin is offline
Autozone usually carries them. For like a 1-2 dollars ea. I broke of 3 @12:30 am replacing a flat low pro.
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 04-18-2003, 05:38 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
http://www.fourthgenhatch.com/wheelstud.html
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
