R061, R062 - SIR Indicator Circuit Failure
Hey all -
The codes R061 & R062 (SIR Indicator Circuit & Redundant SIR Indicator Circuit Failure) have appeared in conjunction with these symptoms: Gas gauge reads E, Voltmeter reads 0.0, chiming constantly when lights are on, Twilight Sentinel not functioning, cruise control not functioning, remote fuel door/trunk release not functioning. My troubles began when my alternator began to fail a few weeks ago, I have a feeling that the low voltage condition might have caused one of these sensors to heat up and blow out breaking the circuit... all fuses check out OK. I did some searching, and I found two other threads on other forums with the same exact symptoms with the same codes thrown, I attempted to get in touch with these people as nobody had found a workable solution for them but the threads are a number of years old already and I got no response... The threads I found were here (94 DeVille problems) and here (R061,r062,gas Gage,no Volt,chime). Does anybody have an insight on where to begin on this problem? Car is a 1995 Cadillac Sedan DeVille, 4.9L. Thanks in advance |
Re: R061, R062 - SIR Indicator Circuit Failure
You need a factory manual to track this down, or a alldata.com, subscription.
Traced it all to a faulty fuse (Ign 1) in the engine comp. Problem solved
