Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-23-2010, 09:46 AM
94&92Astro 94&92Astro is offline
PO- Misfire #4 Oil in plug hole
I got a miss on my 97 CV and when I pulled the plug it had alot of oil present. Other plugs I pulled did not. Indication of bad head gasket? Piston Rings? I changed the manifold a couple of years ago. Engine has about 70k original miles---where to start?
Old 03-23-2010, 12:43 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: PO- Misfire #4 Oil in plug hole
I'd guess valve seals.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-23-2010, 06:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Was the oil on the threads or on the plug electrodes? Makes a lot of difference. If it is on the electrode, possibly valve seals as Blue stated. If it is on threads, look for valve cover leak.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
