Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 04-17-2003, 07:37 AM
Cavaturbo Cavaturbo is offline
Question about the Wheel bearing RECALL
If the rear wheel bearings has been replaced due to a recall, will I have to keep replacing it or when they recall the car, they totally fixed the problem? thanks cuz i am planning to buy a 2001 zx3 with a wheel bearing recall so i am just wondering if i have to keep replacing the wheel bearings.
Old 04-18-2003, 06:51 PM
fordman123 fordman123 is offline
The recall is for the possibility of corrosion to the wheel bearings.
The dealer will replace with a revised bearing that has a protector
shield to (hopefully) keep water from entering the bearing.
Whether this will work or not, I don't have a clue...probably NOT!!
But then again, the main vehicles that would be affected are the ones up north where the salt is used and corrosion is a big issue,
but here in the south, I haven't seen a corrosive wheel bearing yet!!
Hope this answers your question.
Technical Consultant
Old 04-21-2003, 04:57 PM
freakray freakray is offline
AF Modelrater
One the wheel bearing has been replaced, you should not need to think about it again for a very long time, but considering the lack of quality I have found the Focus to be subject to, I would imagine it may be a yearly maintainance thing......hey, fuel pumps are meant to be something you never think about right? I just replaced mine.....
AF User Guidelines
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
96 Eclipse 2.0 Manual Wheel Bearing Question AdrianT Eclipse Problem Diagnosis 1 09-20-2010 08:05 PM
Grinding Wheel, Not the bearings. Kbrickman Cavalier Problem Diagnosis 5 04-18-2009 10:22 PM
question about the august recall bubba4life Town Car 7 09-10-2007 08:30 PM
