Old 04-16-2003, 08:44 PM
stockcav stockcav is offline
Question shaving locks, door handles etc
how do you shave down your door handles, locks, etc...i've seen tons of pics with this done and i'd really like to do it so any info would be helpful!
Old 04-16-2003, 08:53 PM
GZusREVolution GZusREVolution is offline
http://www.autoloc.com/shavedalarm.htmlhttp://www.autoloc.com/shavedalarm.html
You can smooth out your ride a few different ways. Check out Autoloc for some decent kits. What ride are u shaving out. Just door handles?
Old 04-16-2003, 08:55 PM
it's a 98 cavalier...everything is pretty much stock right now but i'm getting custom pipes made now and i'm lookin into gettin a drift body kit
Old 04-16-2003, 09:06 PM
If you can do body work or have friends who can help you , I think it's a little more fun. I bought a Beretta GT years ago (my 2nd car). I all ways wanted one because the door handles look shaved . I ended up getting in an accident and paid a guy I met in the body shop, at the dealership that I detailed at, to paint the whole car. He was cool. I gave him $1000 and he shaved out all the side body moldings,smoothed out all prev. blems and sprayed it Sherwood Pearl Green
Old 04-16-2003, 09:16 PM
i need to add somethin on to this and ask how you shave off the side moldings...i've heard you can use dental floss but it seems like it would just break?? thanks for the info
Old 04-16-2003, 09:28 PM
Dental floss? I've believe in good dental hygiene, but that's a streeeeeeeetch !! WHUD JU HERE
Old 04-17-2003, 04:23 AM
haha that's what i thought too
Old 04-17-2003, 05:44 AM
Pikachoo's Avatar
Pikachoo Pikachoo is offline
Send a message via AIM to Pikachoo
Originally posted by stockcav
i ...i've heard you can use dental floss ...
Fishing string..
You're right, dental floss would probably just break!!
Cruising a Z24 right now, But I've got plans....
http://www.lingenfelter.com/lpe%20-%208%20sec%20Vette.mov
Old 04-17-2003, 07:14 PM
okay so earlier today i removed all the emblems from my car (chevy bowties, cavalier, and chevrolet) and i'm wondering about taking the molding off now...i used some trusty old 12lb fishing line to get off the emblems and they came off perfectly and just had to scrub a bit to get all of the sticky crap off...but if i take the side molding off what can i expect? is it gonna clean up okay or am i gonna have noticable lines?
Old 04-18-2003, 09:56 PM
When I took the moldings off my Beretta, there were little holes I had to fill because the moldings clipped on. You should try to find out if yours are stick on or clip on. If they stick, you should be able to clean them right up, no painting. Also under the moldings was even w/ everything and the sheet metal was smooth on the Beretta......but when I did my Mustang the side body moldings were recessed and I had to use filler to make smooth after removing them. In both cases I was painting the whole car so it didn't matter and I filled, sanded and smoothed whatever needed it. The end result always looks clean and cool. If you want to do your door handles , remove handles tack sheet metal under opening and fill , sand and smooth it. Obviously you will have to line up some paint work. Also order and install Auto loc door shave kit or similiar item...these systems are not that difficult to install and come with everything you need including fairly explicit instructions (although they can be a lil' mo' expensive then using ol' cadillac trunk poppers out of the bone yard). I think they are worth it. Take a look, see what you have to do, and if you want to smooth it all the way defly consider getting the car painted(custom body/ custom color Sorry so long , trying to be thorough.......good luck!!
GZ
Replacing Jeep Wrangler '00 door handles edaydesign Wrangler 0 08-08-2009 06:40 PM
Shaved Door Handle How To??? kicker1_solo Engineering/ Technical 20 07-28-2007 06:45 AM
started shaving my door handles today......... CRXsk8er '88 - '91 Civic | CRX | Wagon | Shuttlee 7 04-06-2003 11:10 AM
How Much does shaving the door handles cost? Rein Exterior | bodykits | Lighting 11 03-23-2002 02:43 AM
Shaved Door Handles on P10 str8maxn Cosmetics 15 11-08-2001 05:24 PM
