| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
1996 LSS surging and stalling....
I have a '96 non-supercharged LSS. I recently bought it from an old lady (purchased about a month ago). It has 75k orig miles on it. Didn't have any mantainance record so I have just been trying to replace everything that I can think of just for the heck of it.
Problem is while in traffic seems to happen the most.... when I am kinda stopping and going the RPM's will rise to 1500-1800 and the car will want to drive while I am pressing down the brake. If I bring it to a complete stop the RPMs will come down after a few secs. It will stall sometimes. Sometimes like this morning I had only made it about 3 miles from home and on residential street it stalled. It will always start right back up. things I have done so far: changed spark plug wires (was told the plugs were good), air filter, fuel filter, new starter, new tensioner pulley w/ new bypass tubes. I wish I knew how to post a pic cuz it looks like someone may have put the wrong Mass airflow sensor on it. Any info would help. (it doesn't die everytime I drive, kinda intermitten) thanks |
Re: 1996 LSS surging and stalling....
What are the numbers on the MAF. Posting pics is easy, 1st you need to setup an account with an online host. Most use www.photobucket.com. It's free BTW.
It's possible that the MAF is the problem. You really need a scanner to check it properly but you can try unplugging it & see if it runs better. Vacuum leaks are a strong possiblity as well as the PCV valve. Try removing the oil filler cap & cover the opening with the palm of your hand. If you feel a strong vacuum then replace the PCV valve & repeat the test. Engine needs to be running while testing.
I had a similar problem with a '94 I have. Would idle high (sometimes shoot up to 1500-1800rpm) at idle, and would also stall when I let off the gas while driving. Started back up every time.
Replaced the IAC (Idle Air Control) first, but that didn't fix it. Unplugged the TPS (Throttle Position Sensor) and the car ran fine. Replaced the TPS and haven't had the problem since. Not saying it's your problem, but thought it worth mentioning. Good luck. |
One thing i forgot to mention I believe this car was sitting around for a while prior to me buying it. Reason I changed the wires was it looked like an animal had been chewing on them. When I first remove the sight guard (?) there was all this stuff underneath it like a nest or something. LOL |
Did you try unplugging the MAF?
Double check that none of the spark plug wires got mixed up. Also make sure none of the wires are within a couple inches of the O2 sensor & wiring. Examine all the vacuum lines & wiring for any damage from your furry friend. |
Actually, the wires may be close to that O2 sensor. I will check again. BTW.... where do you add power steering fluid??? I was doing that stuff to it yesterday and it occured to me .. "where the hell it the power steering resevior?" Last edited by TCHRISD; 03-23-2010 at 11:23 AM. |
Yeah, it's ok to drive around with it unplugged. Some people report back that it ran like crap with the MAF unplugged & others notice an immediate improvement.
Also , now my check engine light is on. I drove to work today and it was basically the same as it had been. Yesterday I view the firing sequence on Autozones website. Weird thing is the numbers on the cylinders seem to be the same but on the coil thing my numbers are in different order. the part in my car has them labeled and they are in different order as the diagram from autozone. com. ????? WTF... I went to lunch and my car wouldn't start. No cranking or anything but all the lights were on. Came back from lunch(walking) went to car and it started right up??????IDK Last edited by TCHRISD; 03-24-2010 at 02:33 PM. |
any ideas??? now that i have read about other cars surging ,i think it happens mostly on inclines. Does that usually indicate a certain thing? Last edited by TCHRISD; 03-25-2010 at 10:05 PM. |
i guess i spoke too soon. this morning it was up to its old tricks again, although the TPS seemed to help a bit. I died again after a couple miles away from the house and then it surged and stalled after about 25 miles. I wasn't on an incline though.
When does it stall? Just when coming to a stop, while cruising or both?
We also need to know if you're losing any coolant or seeing excessive steam from the exhaust.
