Old 04-16-2003, 04:47 PM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
weight of my block
what is the weight of my block???? i want to kno if i can just drop it down without a lift......thanks
Old 04-16-2003, 04:56 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
It looks like you are working on your vehicle indoors. Can you just use a chain hoist or a come-along (hand-powered winch, costs about $12 at Walmart) hanging from a roof beam?
The motors aren't that heavy, but you will need something so you can carefully lower it into place...wow. I just realized, (since I've never done it with a Honda) when you're swapping engines out of an American car, like my 1968 Oldsmobile, you winch the engine out, and then roll the car away...but you can't do that, since there are no wheels on the front! You took 'em off!
Yup. You just might want a cherry-picker, so it'll be on wheels. The motors aren't that heavy, but weight isn't the problem; it's holding them in just the right place so you can get the bolts into the mounts. That part is kind of delicate.
Flunky
Old 04-16-2003, 06:02 PM
Flunky
no im not dropping the engine in now im just taking mine out....everything is out just the block it on just by one motor mount and a jack i just wanted to kno howmuch it weighed maybe i could just lift it down if two of my friend come over...........when i get the ZC im goign to get a hoist or whatever you call it but i dont want to rent one just for this cause im not going to get the ZC for a while and i was goign to put the wheels back on and lift it out but this is easier i just have to drop it down i took the tranny out so far and it was nothing.........thanks
Old 04-16-2003, 06:23 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
you could prolly do that with at least two other people. i had a friend and my dad help lift mine... it was kinda heavy, but then again i had it all assembled. just be carefull you dont drop it.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 04-16-2003, 06:30 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
a friend of mines picked up a z6 that was on the ground and put it in the bed of a truck, by himself. big guy though, idk how big u are. i say right tools for the right job, cause what if u drop it, thats a pricy mistake. if u do fuck up, it would have been cheaper if u just bought the cherry picker
when i took out my motor, well i have a cherry picker so yeah, so it was easy for me
Team Lonely Drivers
Old 04-16-2003, 06:33 PM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
i would say the block alone would weigh approx. 50lbs.
when i ripped the a6 out of the si i just unbolted it all and lifted it out, the whole engine is heavy, but not THAT bad
94 Integra LS, autotragic, Tons of mods
93 Accord wagon, Manual conversion and f20b swap in the near future!
Old 04-16-2003, 06:42 PM
i dont really care if i drop it cause it is shjit anyway but if i did drop it its only like a 16 inch drop im goign to drop it throught the bottom of the engine bay since nothing is on itill have a little jack under it and let is down slowly.........its not that heavy i can lift it with just one motor mount on but it will be heavier with out thatwell see tomorrow.........thanks
Old 04-16-2003, 08:29 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
You can lift it out with a come along and then lift the front of the car with a floor jack and roll it back. This is how I did mine. Make sure you have someone to push the car and someone to hold the jack. I lifted the car by the front crossmember. The front end with no motor is light enough that you can lift it. So if you lift by the place right in the middle theres a place that will fit down in the jack almost perfect.
86 buick lesabre estate wagon with 70's olds 455 big block engine in need of help kcbuechler LeSabre 29 06-26-2012 09:21 AM
K&W block sealer after failed head swap Bob9646 Thunderbird 4 07-19-2009 09:33 PM
Cracked block? BresRodeo Rodeo | Passport | MU 7 04-25-2009 01:02 PM
cracked block? Feeenxxx General Discussion 1 03-17-2009 06:09 PM
